C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
ECS Round 2!!!!
Old Oct 17, 2011 | 06:14 PM
383's Avatar
383
Originally Posted by Matt @ ECS
We use a fuel block to draw fuel from the tank to an external pump. We also still use the factory pump and tee both together. We use the external pump with a hobbs switch included to only turn-on in boost. The Stage 1 system uses a Bosch 044 pump and we have made 900+ with this particular pump.
Any further information please let me know. The cost on the Stage 1 system is $1295, on sale for $1195 right now.
- Matt
That sounds better than a BAP to me. Is a "fuel block" basically just a Y, to split 1 line into 2? How tough is this kit to install? I am very tempted to get this kit right now and install it this winter.
Old Oct 18, 2011 | 09:12 AM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Our guys can install the stage one kit in 3-4 hrs. First time might take an extra hour, but it's not tough to do. The fuel block goes into the tank for the secondary feed, you do not need to drop the tank to install, and we supply you with the necessary tools to install it with the kit. Everything is in the back of the car near the tank besides wiring, so it is a very clean install, factory engine covers stay etc.
The feed block insures a proper seal to the tank fitting rather then just drilling the tank and putting a pipe fitting in there which I have seen always end up weeping. It also has a fuel filter on the pickup side, and
You can also grow with it if your fuel demands increase down the line.
btw, your reason for editing your post made me laugh.
Old Oct 18, 2011 | 09:23 AM
nmalik3000's Avatar
nmalik3000
Sorry guys I didn't post the final dyno graphs as I have been very busy with work. My final results with the headers and a retune via Doug were 578 rwhp and 526 rwtq! I am very happy with the work ECS did for me! Don't hesitate to use them guys! I will post the dynos later when I have time.
Old Oct 18, 2011 | 05:47 PM
nmalik3000's Avatar
nmalik3000
Boost peaked at 8.7 psi at redline, which I think should be safe.
Old Oct 18, 2011 | 09:56 PM
383's Avatar
383
Does the stage 1 fuel kit for the Maggie still include the fuel rails? The factory Maggie kit comes with bigger rails right?
Old Oct 19, 2011 | 09:25 AM
Matt @ ECS's Avatar
0Matt @ ECS
Former Vendor
The ECS Stage 1 Fuel System is not just for the Maggie cars.. It is a universal system for all boosted C6's.
You can read more here:
http://forums.corvetteforum.com/c6-f...whp-rated.html
