Is Quaife torque biasing differential worth it??
Former Vendor
Go figure, we have had a handful of the regular racers at our Corvette challenge events install them with no luck what so ever? Not install problems/gears etc, and built in different locations, but shafts breaking, gears wearing out inside the carrier, that sort of thing.
When a shaft breaks in the quaife it instantly overspins internally and it will gall the side gear within the case.
When we install quaifes in a higher powered car they always get both 300M shafts. In this configuration we haven't had any fail.
When quaife changed thier distributers here in the US, they had to make thier own shafts as the previous supplier made the shafts for them. The new shafts that were made were not nearly strong enough for most corvette racers and they broke.
BJK
This looser didn't get any response on the same question: http://forums.corvetteforum.com/c6-t...y-got-one.html
If I remember correctly, which is a rare thing these days, the guys who used them on the strip talked about a weird feel from the rearend as it hunted back and forth from one side to the other to maintain traction.
BJK
BJK
Funny you mention that, because I've driven a car with a Quaife differential. It was a modified 335i BMW making around 400 rwhp, and it had that weird, unstable feeling under hard acceleration. The back end would feel like it wanted to sway from side to side. Not 100% sure, but I think the owner installed stiffer M3 subframe bushings in the back and it cured the problem. Not sure if it was a Quaife thing or just a power thing.
Earlier today I was on the phone to a couple of places back east checking on what it would cost to have my DTE Stage 4 diff upgraded to a 3.73 ration and also include the Quaife at the same time. It seems to me that I found the mention of the weird feeling of the rear end in the C5 section regarding drag racing launch.
BJK
BJK
I would imagine the torque transfer between sides could cause this. More torque on one side would steer the car away from that side. Of course any diff losing traction on one side could do this, but it would be exacerbated with the torque transfer, just a gut feeling. I never really liked the principles behind the quaife, maybe because it's hard to fully understand. Maybe that's why I like the OSgiken, apply torque, wheels lock, end of story (not really).
I believe also the quaife acts to try to force no wheel slip at all, but some wheel spin is advantageous for traction.
Yea, not sure how good the factory diff is, but a lot of OEM diffs will be overpowered and slip. Not sure what the specs are on the OEM diff, anyone know?
I got my DTE Stage 4 back yesterday. I had the Quaife and a 3.73 ring and pinion installed. I have a lot of other things that I'm finishing up also, so it will probably be after the holidays before I will be able to road test everything.
Which one of the DR Rippie oil coolers did you install and what did you thing the kit. Any pictures of the install?
BJK
BJK
This is a photo Randy sent me before I installed the cooler. Note that the pump is electric. I used a Zo6 type pump in my new ZIP Corvette Quiaife LSD.
The next time I put my Vette on the lift I will take photos of my LSD & Cooler. Randy said that the cooler will drop the oil temp by 40 deg F
Last summer I had a new Race Duty Quaife LSD built and I installed it in my Corvette track & street car. I really liked the performance of the new LSD at Watkins Glen & VIR race tracks.
Last evening Andrew Gleasman, the VP of sales for Torvec gave a talk at our local Rochester Corvette Club meeting on the IsoTorque LSD. They said it was considerably better that the Quaife LSD that they tested showing much faster cornering speeds.
They had performed test at Watkins Glen International Raceway
When I got home from the meeting I searched out comparisons’ on the Quaife VS IsoTorque and I found a post on the following web site on the subject:
http://www.350zmotoring.com/forums/g...e-sign-up.html
I copied the following statement by Andrew Gleasman from the 350Z post:
“The Quaife is a parallel axis differential and has a torque bias ratio of only 2:1, meaning that if you have one wheel on grass and one on pavement the difference in the coefficient of friction of the two cannot exceed 2:1 or one wheel would spin up like an open diff. Meaning once the internal friction of the gears binding is overcome the wheel will spin. The viscous unit and the clutch type both have roughly a 2:1 bias. The Quaife and other parallel axis differentials are an offshoot of my grandfathers patents for cutting small number of teeth without under cut in 1951.
The IsoTorque and the Torsen type 1, are called cross axis differentials, they do not use internal friction to prevent will spin and they do not bind. The Torsen currently has a bias of 3.5:1 – 4:1, but the improvements on the IsoTorque are upwards of 8:1 torque bias. This ratio allows the IsoTorque to drive a split coefficient of something like Ice under one wheel and pavement under the other. The added benefit is when going around a turn if need power can be sent to the outside wheel with the most grip up to 8x that of the inside wheel helping turning and safety.
The IsoTorque has no limitation on where it can be installed, either the Z with the open diff or like our test car 35th Anniversary with the LSD, it is compatible with all traction controls, ABS or stability control systems.”
I sent Quaife an email asking them what they thinks about this comparison. Is all of this bias ratio data correct? Is power of 8X ever needed on the outside wheel of that of the inside wheel?
I told Andrew that I have a Quaife LSD and I like it very much in comparison to the OEM LSD . They offered to change my Quaife for their IsoTorque at their shop so I could see the difference. That offer is not realistic because I do not have a problem with my new Quaife LSD and I have too much time and money in the installation that included a diff. oil cooler system, polished gears and special race bearings etc.
I had tried to purchase a IsoTorque LSD last year before I desided on the Quaife. I found that Torvec did not yet have the IsoTorque ready for market at that time for the Corvette but Quaife did.
It would have been nice to have a LSD that was made in the USA!
The Torvec factory is 35 miles from my home in Rochester NY.
We were told at the RCC meeting that the Torvec LSD is going to showing up on some new performance cars as a OEM part. They would not tell us what car , but former GMHP Div. Engineer and driver John Heinricy now works for Torvec??
Im on the fence of getting a qualfe or not..high hp drag...and mostly street...is it really worth 900 more over carbon clutches?
I like my quaife, I will a test to the feeling you are all asking about as it is similar to my AWD car accelerating hard in the snow. You floor it and the rear wiggles about one inch side to side but the tirs stay hooked. To me its the warning that anymore power would lead me to spinning.
As far as a dependable and durable differential look no further than the Quaife for your high HP needs.
Mine has been running great for about 5 years now. In my experience the rear dances less than with clutches. With this thing it digs in and stays straight much better, especially on the shift.
I agree with both posts above. My last 3 corvettes were clutched diffs and those cars would always start going sideways when the tires were spinning hard. My current car is the first corvette I have driven with a Quaife and even when boiling the tires or just lightly spinning them the car stays very straight and predictable and any speed.
