Header rattle noise, please help!
I am noticing that when the car is cold and I start up the car, I hear a noise coming from underneath the car where I believe the headers are. It's like a wobbling or rattling noise. I am sure it isn't valve train noise because when the car is parked I don't hear any noise, only when moving slowly after a cold start and even when I put the car in neutral and am coasting and go over rough surfaces.
The weird thing is that once the car is fully warmed up, the rattling noises go away completely... Could it be due to expanding/contracting of the steel due to the temp differences and something coming into contact? Do you guys think something is loose under there? Unfortunately I don't have access to a lift to take a peak. Just odd the noise goes away after the car is fully warmed up. I know the noise is due to the headers because I didn't have this problem before.... Car runs great otherwise! Thanks for any suggestions guys!!
Call Doug and tell him you started a thread asking for help about a noise under your car, I have never had an issue with my headers and I don't think anyone else ever had that problem.
The problem you are having can be cause by your tune, before the car is warm up properly it idles rough and with a good tune those issues don't occur. Call the shop because a good shop leaves no stone unturned.
Had the tranny lines bent around the header to fix the problem.
Raj, you know your welcome to stop down anytime if you wish to have it looked at though.
Thanks for the compliment Mario, that was very nice of you.
