C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Problems with Snow Performance Meth?
Old Oct 12, 2011 | 05:48 PM
walhan_qtr's Avatar
walhan_qtr
we have a Z06 with the same kit and it failed 3 times. we got brand new parts and still every month or two it will start leaking. fixed it three times and failed AGAIN! it will be off the car to the trash when we switch to E85......
Old Oct 12, 2011 | 06:45 PM
Six-Gun-Todd's Avatar
Six-Gun-Todd
Originally Posted by 06.Z51.MontRed.Vert
Not liking the idea of straight methanol being sprayed onto red hot headers Methanol self ignites under 900 F. I'd be willing to bet that header temps easily reach that point...
Yet many tune it that way.....my guess is to slightly reduce duty cycle while lowering inlet air temps. The funny part about it is the fact they are giving up the lower egts and higher octane when running a meth water blend.
Old Oct 12, 2011 | 06:56 PM
BoosterClub's Avatar
BoosterClub
Uh, from a tuning and power perspective, 100% is definitely better, water doesn't increase octane (over the meth). Not commenting on it's safety.
Edit: I see you run a diesel engine, not the same thing. Completely different dynamics.
Old Oct 12, 2011 | 08:03 PM
Six-Gun-Todd
True....but I've run water meth on gas engines for about 20 years now so I'm by no means an late adopter. The water component actually reduces the gasolines propensity to ignite....or improves it's octane rating more so than methanol alone. I will not argue that straight meth makes more power.....but as the saying goes playing with fire
Old Oct 12, 2011 | 08:16 PM
RMS-MAN's Avatar
RMS-MAN
Julios Alky Control kit is the only option for solid meth kits on the market. Period.
Old Oct 12, 2011 | 08:17 PM
BoosterClub
I'll just let you stew on that for a while, and defer you back to my original comment.
Old Oct 12, 2011 | 08:22 PM
Six-Gun-Todd
Tisk tisk young blood....power isn't everything.
Old Oct 12, 2011 | 08:30 PM
BoosterClub
P.S. what a bunch of idiots we are for running hoses of a flammable substance through our engine bay, I don't know any cars that do that. . .
Wait. . . I meant I don't know any cars that doesn't do that, my bad.
Old Oct 12, 2011 | 08:40 PM
Six-Gun-Todd
Hahaha...true enough...but I doubt you store roughly a gallon of it in the engine compartment
Old Oct 12, 2011 | 08:52 PM
BoosterClub
No, but I store about 16 gallons of it in the back which will very quickly evacuate itself through a -10 line into the engine compartment if allowed.
Problem here is people use crappy components, not that they are dealing with a flammable liquid. Or maybe it's that people have less respect for methanol then gasoline and think they know enough to play with it themselves when they don't.
Old Oct 12, 2011 | 09:04 PM
Six-Gun-Todd
Bingo
Old Oct 12, 2011 | 11:45 PM
CK@UPPCOS's Avatar
0CK@UPPCOS
Former Vendor
Oh yea, that's an O ring going bad. I wouldn't use swivel fittings on methanol systems even if they say they are OK. You should be able to clock an NPT thread wherever you need.
It's what came with the kit, and apparently it's a special fitting machined to accept their nozzle. (one of Snow's former employee's works for me)
CK
Old Oct 12, 2011 | 11:54 PM
  #33
CK@UPPCOS's Avatar
0CK@UPPCOS
Former Vendor
You too? Why didn't you ever say anything? Do you have some of the failed fittings still? I'm going to try to have a sit down with Matt Snow, not sure if it will accomplish anything, but it's worth a try. My employee said that Matt did purchase an engine for a customer before with a failed meth kit, so ???? maybe. Course I can't 100% attribute it to the meth, but it does make sense.
On a side note, we usually run 100% meth. I think when we tested it at 25% water it stopped being flamable. But with a good IC and low IAT's there really wasn't enough heat to fully evaporate the water, so the compression increased, and we actually saw MORE detonation than without anything at all. I'm not the biggest fan of meth for such reasons, but I'll say it does have it's place, and some customers prefer it over E85
CK
Old Oct 13, 2011 | 12:21 AM
  #34
walhan_qtr's Avatar
walhan_qtr
CK
I wasnt aware that AB was running the same kit. and he told me you guys fixed it. the kit on the Z06 was installed when my buddy bought the car. good thing the car wasnt tuned on meth for a long time. when we noticed that it was leaking we tuned it with out the meth. fixed the leak and a month or two later when my buddy decided to retune his car with the meth we noticed it was leaking again. fixed it and a month later it started leaking. so he decided he will just switch to E85 and take that kit off his car.
I am sure he threw all the fittings away, but I will check for you. hopefully the shop kept them.
Old Oct 13, 2011 | 08:56 AM
  #35
Six-Gun-Todd
CK
That's why I like the ECS method of installation for the alky control....positioning the nozzle before a separate IAT sensor. If the system fails or you run out of w/m the tune can be setup to revert to normal operation.
Old Oct 13, 2011 | 10:13 AM
  #36
Unreal's Avatar
Unreal
Once my car runs, if my heads ever show up, I'm buying the ECS kit. Never seen an issue with it and ECS supports their customers.
Old Oct 13, 2011 | 10:36 PM
  #37
Taylor@DallasPerformance's Avatar
0Taylor@DallasPerformance
Former Vendor
AlkyControl does wonders. We pull off the snow junk all the time in favor of the AlkyControl. Sorry to hear about your problems...
To Problems with Snow Performance Meth?
Old Oct 14, 2011 | 12:32 PM
  #38
wooden's Avatar
wooden
yep I have had the fittings fail too. I redid everything with -4an braided lines.
Old Oct 14, 2011 | 01:25 PM
  #39
C_Williams@RPM's Avatar
0C_Williams@RPM
Former Vendor
Originally Posted by Bobby @ LG Motorsports
Yes, its common with them, which is why we use 100% stainless braided lines and a custom nozzle adapter.
yes........and we also offer an upgrade to a stainless steel, magnetic drive pump and BLDC motor...not cheap but then again, what's the cost of an engine worth...
Old Oct 14, 2011 | 02:26 PM
  #40
d.medic's Avatar
d.medic
St. Jude Donor '10
If I was Snow I would jump in here. Admit the product is faulty and come up with a fix. Some pretty big hitters in here, and all of them don't have much nice to say about the kit.
