C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
how do blower restrictors work?
Old Nov 17, 2011 | 09:55 PM
BoosterClub's Avatar
BoosterClub
I like the wastegate idea more, more control for one, plus I'm sure the restrictors cause a drop in efficiency, they are essentially increasing the pressure delta across the blower by creating vacuum in the intake, where as the wastegate actually lowers the pressure delta (higher pressure delta = more power loss to turn)
Real question is why, octane? Is peak octant requirement at peak torque or HP?
Old Nov 17, 2011 | 11:16 PM
Slowsome's Avatar
Slowsome
on my ecs kit, I started with a 10 psi restrictor... I opened it up to 12 psi..... then i made a pull to 6000 with out the restrictor.... the 12 psi restrictor and the non restricted pull were identical until 5500 rpm... thats when the non restrictor really took over....
