C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Ported LS2 manifold?
Old Dec 28, 2011 | 02:01 PM
Corvette-Chris's Avatar
Corvette-Chris
St. Jude Donor '08
Default Ported LS2 manifold?
Have any of you guys or shops ever used a ported LS2 intake manifold that held up well under boost? Getting a FAST is out of the question and I am just looking for ways to help my car breathe a little better and be more efficient.
Old Dec 28, 2011 | 02:23 PM
FloydSummerOf68's Avatar
FloydSummerOf68
FWIW, I took my ported FAST off when I did my A&A blower and had no problems making over 600rwhp on a 3.8 pulley with a stock motor. I saw so many people making huge numbers on a stock intake I didn't see the benefit.
Why not spend the money for a smaller pulley or meth?
Old Dec 28, 2011 | 02:34 PM
Corvette-Chris
St. Jude Donor '08
I have meth, but no pulley. It's a TT car.
Here's my logic:
I want to make the most amount of reliable power without boosting the car through the moon. I'm still using stock heads (with ARP 2000 head studs) and APS journal bearing turbos. Both of these would last longer and be more reliable if I helped make the engine more efficient and didn't spin the turbos to the edge of destruction.
They claim 15-20rwhp in a NA car with a "stage II" ported LS2 manifold. I would think at 15-16psi of boost, I would even see better results. Yes? No? If the power gained would be worth the $2-300, I'd probably do it.
Old Dec 28, 2011 | 03:05 PM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
Just my guess but I think a ported LS2 manifold would only gain ~5 RWHP/TQ on an FI setup.
Old Dec 28, 2011 | 03:17 PM
Corvette-Chris
St. Jude Donor '08
Well, if thats the case, it's definitely not worth it in my eyes.
Old Dec 28, 2011 | 05:34 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
You know my previous setup had a LS2 intake on a 403 and what power I made.
You know what I make now with a 434 and a Vic. Jr.
I think you'll have a known-good intake with no troubles under boost.
Old Dec 28, 2011 | 06:10 PM
user_name's Avatar
user_name
Not money well spent IMO. If you are concerned about it being efficient, wouldn't it make more sense to reduce backpressure and/or lower IAT's?
Old Dec 28, 2011 | 06:48 PM
Corvette-Chris
St. Jude Donor '08
True.
I think I've addressed as much of a backpressure issue as possible. IAT's could prob decrease with E85, as that has been a goal of mine.
Old Dec 28, 2011 | 07:23 PM
slow ride's Avatar
slow ride
I wouldn't cut the supports inside the plenum for porting though. I'd think the flat bottom would flex without the extra support nder high boost pressure. I'd just do light cleanup where the tb bolts to the intake and around the runners as deep as I could reach. I wouldn't expect to set the world on fire doing this, but every little thing adds up, well most of the time
Old Dec 28, 2011 | 07:52 PM
Tally Ho's Avatar
Tally Ho
From: Out Where the Buses Don't Run, Eglin AFB/ Niceville FL
2022 Corvette of the Year Finalist -- Modified
2021 C6 of the Year Winner - Modified
2020 C6 of the Year Finalist - Modified
I've been running FI on a stock ported manifold for a little over two years now with no issues.
Old Dec 28, 2011 | 08:38 PM
mdaniel's Avatar
mdaniel
Banned Scam/Spammer
I'm sure a ported LS2 90mm TB and intake help, but for hundreds of dollars I can't see the point. Even if you gain 15-20 hp. So what. That doesn't justify hundreds of dollars in hardware + another $500 for tuning IMO. For competitive racers where a tenth means something then maybe, but for everyone else it's a waste.
From my perspective any mods that don't net at least 40-50 hp aren't worthwhile. Just my .02.
Old Dec 28, 2011 | 09:49 PM
Corvette-Chris
St. Jude Donor '08
Thanks for the input guys. Tuning isn't a issue. I'm putting an entire new motor in the car right now anyway.
To Ported LS2 manifold?
