C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
E-Force IAT Sensor/ T-Map Clarification ??!
Old Jan 3, 2012 | 04:14 PM
WHITE_SHARK's Avatar
WHITE_SHARK
Hi guys,
due to limited internet access for Am o u d i, he requested to know from where he can check these values using EFI Live application?
Old Jan 3, 2012 | 04:27 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
Originally Posted by A m o u d i
All the time 150 C after running for a while. But I will check today from a cold start and I will update u.
I had an issue where the fuse for the intercooler pump blew and my iats were hanging around 150 as soon as it warmed up. Obviously if its 150 at a cold start and stays at exactly 150 that can't be the issue but I'm not clear on those details from your posts.
Old Jan 3, 2012 | 04:56 PM
yonson's Avatar
yonson
Originally Posted by WHITE_SHARK
Hi guys,
He can check the MAP sensor parameters under, Engine Operation, MAP, the IAT parameters are under Engine Operation, Fuel, General, IAT Sensor Scaling.
Old Jan 3, 2012 | 08:33 PM
Motorhead-47's Avatar
Motorhead-47
The simplest thing to do is to reinstall the calibration that came with the handheld tuner provided with the kit. If your IAT problems suddenly disappear then you know the problem is in the "custom tune". I don't have enough fingers to count the number of E-Force "custom tunes" that I have run across that were hosed up!
Old Jan 12, 2012 | 05:34 PM
A m o u d i's Avatar
A m o u d i
Hi guys,
This is a screen shot was sent to me today by the tuner.
As you can see there is no IAT scaling
Is this normal for 2005. then where I can set the parameters that mentioned in edelbrock website:
"NOTE: If you have a 2005 LS2 it will limit the Linear to 255.9 and the offset can't be below 0 so just use those values and it will be fairly close." ???
Old Jan 12, 2012 | 08:35 PM
Motorhead-47
I don't work in EFILive but I downloaded the software and located the IAT sensor curve all in less than 15 minutes.
Old Jan 13, 2012 | 06:50 AM
A m o u d i
Thanks Motorhead
Old Jan 13, 2012 | 11:46 AM
Chuck CoW's Avatar
0Chuck CoW
Former Vendor
St. Jude Donor '07-'08-'09-'10-'12-'13-'14
Default Yes, that's it....
Yes, that's it....
I've had trouble where you turn the key on and the IAT temp is 300+ F...
That tells you the wiring to the sensor is wrong. When you load the Edelbrock starter tune,
be sure to know which sensor you have (1 or 2 bolt) and then use the serial # of your
head unit to load the correct starter tune from Edelbrock.
All my stuff is in EFI LIVE format so if you e-mail me your tune I can compare it to
what I've been doing.....
Let me know if that helps...
Chuck CoW
Old Jan 13, 2012 | 12:45 PM
A m o u d i
Thanks a lot to all of you for your concern. The IAT Sensor scaling table is not there. It seems this only for 2005 C6. because later model they have IAT scaling table.
2005 automatic stock tune link here (http://www.tunefiledepot.com/calibra...(12595692).tun)
However tomorrow I will go to tuner and the kit installer and I will discuss this thread feedback with them. I believe things will be good
I will update u.
Old Jan 13, 2012 | 03:17 PM
Motorhead-47
I'm not an EFILive guy and like you, at first look I don't see IAT Sensor Cal in the 2005 file you referenced. But...I loaded a 2005 file in HP Tuners and IAT Sensor Cal is definitely in the 2005 calibration. Your issue has to do with using EFILive. Why not go back to the handheld tuner calibration that came with your supercharger kit? That cal will load the correct values.
HP Tuners screen capture from a 2005 file...
