C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Need Help With SCT Programmer /E-FORCE
Old Jan 1, 2012 | 11:05 AM
ZR-1 1991's Avatar
ZR-1 1991
Default Need Help With SCT Programmer /E-FORCE
Need help . I tried to update my programmer all the get on the screen is ''Filesystem Not Found Please reload it .
I have a 2007 Z06 and installed 1572 . Any one know how to fix this ?
Thanks In Advance !
Old Jan 2, 2012 | 09:33 AM
erick_e's Avatar
erick_e
St. Jude Donor '13-'14-'15-'16
Thanks In Advance !
That kind of sucks. Although not much help, a google search of "SCT Filesystem Not Found " reveals its pretty common and that your option is to have SCT remotly upload the operating system.
Old Jan 3, 2012 | 09:25 AM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
There is an on-line SCT Device Updater available to you. I have it on my PC but I don't recall the steps I had to take to get it. I'd visit their website and see if it is something you can download and then try and update your handheld device to the latest information.
Elmer
Old Jan 3, 2012 | 10:35 AM
ZR-1 1991's Avatar
ZR-1 1991
Problem Solved , Thanks Boys. I called SCT Tech support.
I was using a my laptop with wireless connection to update. When you update the firmware it first, erases the old version , then installs new version , If you get a glitch or lose your connection (sometimes happens with wireless). If wipes the programmer out. He had to connect with remote assistance and re -install firmware ,
All Is Good --I hope
Old Jan 3, 2012 | 09:13 PM
billybadd's Avatar
billybadd
Update us when it's done
I've been eying one of these kits!
Old Jan 4, 2012 | 07:02 AM
ZR-1 1991's Avatar
ZR-1 1991
No problem , as for the instructions there are some big errors,A couple that comes to mind , removing the steering rack , It tells you to remove from drivers side , To do this you have to bend your break lines , 'NOT GOOD . but you can rotate 180 then move it to the passenger's side . It tells you to drill the rad shroud ,The Z06 the holes are already there, and the other 2 you drill you don't need. Another 'BIG' one the supercharger don't use the first bolt on passenger side and back bolt on drivers side . The revised instructions tells you to cap it , It you do supercharger , won't go down because it bringers up the the heads of the bolts.
Old Jan 6, 2012 | 12:12 AM
Dknight's Avatar
Dknight
St. Jude Donor '12
I also will be installing one soon this is second time heard of this. I will be calling tech support prior to install. my kit 1575. Any recommendations on exhaust with the e-force and can I still use there tune 2011 gs vert
Dave
Old Jan 6, 2012 | 07:07 AM
ZR-1 1991's Avatar
ZR-1 1991
Dave
I went with the muffler mod, it's the best of both worlds .The car is suppose to be stock to install tune.
Advise , you need a 1/4 universal 10 mm socket to torque down supercharger . I have to order one , will take a week to get it .
Old Jan 6, 2012 | 10:08 AM
Dknight's Avatar
Dknight
St. Jude Donor '12
Thanks for the heads up , will check the tool chest tonight
Old Jan 7, 2012 | 09:41 AM
ZR-1 1991's Avatar
ZR-1 1991
When your ready to do the install ,If you need any help just PM.
Old Jan 8, 2012 | 01:06 PM
Dknight's Avatar
Dknight
St. Jude Donor '12
Thanks will do
Dave
To Need Help With SCT Programmer /E-FORCE
