C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
E Force updates??
Old Feb 1, 2012 | 06:33 PM
Coltsfan1's Avatar
Coltsfan1
Default E Force updates??
Getting ready to pull the trigger.....but before i do has anyone with this set up had any issues?? How is your stock clutch holding up? Any heat issues? Any oil leaks issues? Is it what you expected for the money you spent? I have a manual so Im real concerned about everytime I get on her she breaks loose (going with the 554 kit).
Thanks for any feed back from owners with this unit!!!!!!
Old Feb 1, 2012 | 07:03 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
What year is your car?
Old Feb 1, 2012 | 07:11 PM
Childs' Play's Avatar
Childs' Play
Subscribed.....
Coltsfan,
Where you getting this done. Not to far away from me and I'm having a hard time finding a shop to do tuning / performance installs.
Thanks,
CP
Old Feb 1, 2012 | 08:06 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
My car is an auto so I can't speak about the manual issues, but as far as the eforce, it has delivered more than I expected and I'm happy with it. Outside of a defective part, which edelbrock took good care of I have no issues at all. Yes, you will break the tires loose when you get on it, but that's half the fun.
Old Feb 1, 2012 | 08:48 PM
drich2905's Avatar
drich2905
manual here-and no problems other than me slinging off a belt playing a little hard-got a better belt and for the last 14 months...fun, fun, fun.
Old Feb 1, 2012 | 09:47 PM
Telepierre's Avatar
Telepierre
2008 Auto. Great product!
Old Feb 1, 2012 | 10:02 PM
eboggs_jkvl
Moderator emeritus
Only the 2007s have issues. If you are 2008 and newer, go for it.
Old Feb 1, 2012 | 10:13 PM
JoesC5's Avatar
JoesC5
My Z06 has a measly 505 horsepower, but wider tires then your car, and I break loose every time I get on it. You'll just have to learn a new way of driving, or your *** will be grass and your car will be the lawnmower.
Old Feb 2, 2012 | 08:28 AM
FloydSummerOf68's Avatar
FloydSummerOf68
Get some decent tires.
I recommend the Khumo XS, Bridgestone RE-11, Ventus R-S3 or Nitto NT05. All are very good and very sticky street radials.
Old Feb 2, 2012 | 09:47 AM
C_Williams@RPM's Avatar
0C_Williams@RPM
Former Vendor
We are installing yet another one this week and I'll post up the results. Great systems - you'll like it.
Old Feb 2, 2012 | 01:37 PM
Late Model Racecraft's Avatar
Supporting Vendor
http://www.youtube.com/watch?v=PaQeDXOCZ1g
http://www.youtube.com/watch?v=5xFOh8s7WXI
__________________
Worlds Quickest C8 Corvette 8.83@160MPH
FIRST C7 Corvette in the 7's & 9's
2019 ZR1 LT5 8.874 @ 155
Current C7 World Record Holder 7.55 @ 184 MPH
Quickest and Fastest GEN5 LT Powered Vehicle
LMR1200HP Supercharged C7 8.84 @ 160
LMR1200HP Twin Turbo C7 9.35@155mph-2014
2 TIME OUTLAW DRAG RADIAL LSX CHAMPION 2008/2010
9.47 ZR1 Corvette-2009
LATE MODEL RACECRAFT
713-466-9900
LateModelRacecraft.com
Too many PMs, please call or email instead, thanks!
Old Feb 2, 2012 | 01:40 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
NICE !! Love the sound..
Old Feb 2, 2012 | 08:31 PM
Motorhead-47's Avatar
Motorhead-47
Hey I recognize that car! http://forums.corvetteforum.com/c6-f...ll-for-me.html
Old Feb 4, 2012 | 05:50 PM
Nick@Straightline's Avatar
Nick@Straightline
St. Jude Donor '13
Here is a car we just finished up
Old Feb 5, 2012 | 09:11 AM
383's Avatar
383
Do you know what they were/are?
Old Feb 5, 2012 | 11:20 AM
ZR-1 1991's Avatar
ZR-1 1991
I do, just finished installing one on a 2007 z06 .
1. make sure ECU has latest update 12614676 .when you update you may also have to reprogram the crankshaft position sensor.
2 If you doing it yourself go buy a 10mm universal 1/4 drive socket.and fuel line tool.
3 if it's a Z06 remove steering rack to passenger side 'NOT' drivers side.
4 when car is finished it should sound JUST LIKE IT DID BEFORE SUPERCHARGER WAS INSTALLED.
If you need any more info just email me.
Old Feb 5, 2012 | 01:26 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
My 07 doesn't have any issues to speak of. I know Elmer does but I don't think that issue is too common. On a Z06, or manual car make sure you remove the alternator pulley bolt and retorque it using locktight. I have a few friends who's pulley spun off.
To E Force updates??
Old Feb 6, 2012 | 01:10 AM
Telepierre's Avatar
Telepierre
Also MINOR ISSUE: Original kit I installed provided new brackets for the original horns and the sound result were quite embarrassing (think bip bip cartoon character..). There is a good work around suggestion on this forum.
Maybe E-force fixed it by now...
Old Feb 7, 2012 | 06:56 AM
Frankko's Avatar
Frankko
I am looking to buy one, e force 599 for a 06 A6 base coupe.
I am in Afghanistan and would like to buy and have it installed for when I come back.
Any leads in the Miami area?
I could install also so if I get a good deal.
Frank
Forgot to ask if the 07 issues apply to 06 as well?
Thanks again
Old Feb 7, 2012 | 04:21 PM
ChevyDave's Avatar
ChevyDave
Some notes...
599hp kit (#1591 like mine) will cost some extra due to fuel pump.
installation for fuel pump on automactics require dropping drive train and maybe exhaust which will cost extra. pump installation write-up....
http://forums.corvetteforum.com/c6-t...fuel-pump.html
reinstallation of horn is still incorrect, they stopped sending a new horn bracket but still gets attached to firmly. which causes horn to still go weeeeep weeeeeep. see topic and fix...
http://forums.corvetteforum.com/c6-f...install-3.html
edelbrock remove/install using latest document for 1590/1591/1592...
remove old bracket step 120.
attached horn step 127.
http://www.edelbrock.com/automotive_.../1000/1590.pdf
some use 345/30/19 instead of 325/30/19 tires on rear. if you do and have "Engine drag Control ", size fronts to 1.1 inches of OD of back tires. i filled out the 3rd party limited warrenty and it states oversized tires limits/voids warrenty, just a f.y.i.
see... http://forums.corvetteforum.com/c6-z...this-mean.html
those are the notes i printed and saved before i had mine installed a couple weeks ago.
