C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Does crank bolt require high temp Loctite?
Old Feb 7, 2012 | 08:16 PM
WardVette's Avatar
WardVette
Default Does crank bolt require high temp Loctite?
I'm midway through my A&A kit installation and ready to install the crank bolt. I went to Autozone and they have the red Loctite Threadlocker but it does not say 272 or high temp. I got some that is high strength rated up to 3/4" fastener and 300 degrees. Will this work or do I need to get the high temp stuff? If it is required, where can I find it?
Old Feb 7, 2012 | 10:52 PM
NICK YOSKIN's Avatar
NICK YOSKIN
St. Jude Donor '08
No need. Using a new stock bolt? Id recommend arp balancer bolt. Readily available from most vendors here. Just a couple of bucks so best off going that route.
Old Feb 7, 2012 | 10:58 PM
JMBLOWNWS6's Avatar
JMBLOWNWS6
I have always used it on all of my builds. Just my personal .02
Old Feb 10, 2012 | 12:54 PM
B-Vette's Avatar
B-Vette
I think the crank pinning kit would be more important than the loctite!
On the serious side, it's not needed but to each his own.
Old Feb 10, 2012 | 01:06 PM
DSOMC6's Avatar
DSOMC6
I use red loctite just for piece of mind. However......it usually requires a heat-gun to loosen up the bond when/if you go to remove the bolt.
To Does crank bolt require high temp Loctite?
