C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Bov??
Old Mar 18, 2012 | 07:02 PM
ZZMike's Avatar
ZZMike
Originally Posted by Mr.Big
The setups we are speaking about are all S.D. tuned, the BOV's we run are all open at idle and partial throttle "cruising" and if the bung is at the correct angle only vacuum will be drawn. I've been down this road before with the engine vacuum. If anyone thinks they understand what we are discussing and still thinks/assumes we run a m.a.f. they don't have much of a clue.
I have more of a clue than you do if you think you are generating enough pressure at idle and cruise to keep the exhaust away from the BOV.
PT your idea is solid, it'll just be expensive to fab... I say go for it if it bothers you that much, at 29psi on my setup I'm o.k. with the b.o.v.(s) for now, but would consider this mod if I made more major changes, I think 5 major redos is enough for me on this platform. I say go for it PT, Taylor will do it right...
This is the important part, contact Taylor and get his feedback.
