C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
A&A kit for ls7
Old Apr 4, 2012 | 03:25 PM
CaseyMoser's Avatar
CaseyMoser
Default A&A kit for ls7
I am thinking of going with the a&a kit and running e85. What problems will I incur when doing so? Does anyone else have a similar setup?
Old Apr 4, 2012 | 03:26 PM
Unreal's Avatar
Unreal
Probably want to upgrade the fuel pump and injectors. Si-trim is good for ~700rwhp. If your going for more than that then get a T-trim or bigger. Other than that, the ls7 loves boost.
Old Apr 4, 2012 | 03:32 PM
CaseyMoser's Avatar
CaseyMoser
I'm definitely going t-trim. What type of fuel pump/injectors does everyone usually go with?
Old Apr 4, 2012 | 03:56 PM
ashanson's Avatar
ashanson
I'm using the z06 pump with a KB boost a pump and 83# injectors. Otherwise stock fuel system. I'm thinking the pump will max out in the high 600s on the dyno with e85. Injectors should be good for a bit more than that, probably high 700s. I can let you know for sure after my dyno results, I'm planning around 650-670whp, hoping the pump keeps up.
Old Apr 4, 2012 | 04:08 PM
Unreal's Avatar
Unreal
I am running ID1000s with my A&A kit.
I was running a boost-a-pump with a racetronix harness but I'm upgrading to a RSI dual pump setup so I"ll sell teh boost-a-pump and harness.
Old Apr 4, 2012 | 04:17 PM
CaseyMoser's Avatar
CaseyMoser
Any input would be greatly appreciated. I am shooting for 700 rwhp. How much boost are you running? Stock internals? Daily driver or track/weekend car?
Old Apr 4, 2012 | 04:40 PM
ashanson's Avatar
ashanson
Sure, will keep in touch after my tune. Just running the base ECS kit on a built 427 LS3, only expecting 5psi, might take out restrictor plate for an extra couple pounds if I'm not pushing the fuel system with 5psi. It's my daily driver but one or two autocrosses and maybe HPDE per year.
Old Apr 4, 2012 | 04:42 PM
4SELLL's Avatar
4SELLL
A Si or T trim would work with twin walbro in tank and 1000cc injectors for your goal. Im building a E85/AA vette right now if you want to check it out you are more than welcome.
Old Apr 4, 2012 | 05:05 PM
Unreal's Avatar
Unreal
For 700rwhp do the T-trim. The si can do it but will pretty much be tapped out.
I would do dual pumps or add an external pump for e-85. Then again z06 pump with a boost-a-pump/etc should squeak out 700hp.
Old Apr 4, 2012 | 07:23 PM
Josh@AandASuperchargers's Avatar
Platinum Supporting Vendor
Thanks for your interest in our kit. You can order a T-Trim "tuner kit" that would come with everything except injectors and a boost-a-pump. You could also run our high capacity fuel system, and then source your own injectors.
Here's our fuel system:
http://www.aacorvette.com/supercharg...products_id=66
Give us a call if you have any questions.
__________________
Thanks, Josh Dodson
Sales Manager at A&A Corvette
PLEASE TAKE A MOMENT TO VISIT OUR NEW WEBSITE AT WWW.AACORVETTE.COM
NOW PARTNERING WITH AFFIRM TO OFFER INTEREST FREE FINANCING!
A&A CORVETTE PERFORMANCE
477 LAMBERT ST Ste A
OXNARD CA 93036
(805) 278-4107
Instagram @aacorvettesuperchargers
Facebook.com/AACorvette
Old Apr 13, 2012 | 11:17 PM
ashanson's Avatar
ashanson
Got the tune pretty much done, but couldn't get dyno time for some final WOT adjustments. The kit made 5.5psi around 4500rpms and held there until redline. I imagine I'd see about 7psi without the restrictor plate.
Fuel pump kept up great, so when I'm on the dyno in a few weeks I may take out the restrictor and see if it can maintain pressure at higher power levels.
Old Apr 14, 2012 | 08:31 AM
helga203's Avatar
helga203
E85?
What size injectors?
Old May 7, 2012 | 04:45 PM
ashanson's Avatar
ashanson
Originally Posted by helga203
E85?
Yes, E85 and 80# injectors with Z06 pump and boost a pump, otherwise stock fuel system. Car is making 640rwhp and zero loss of fuel pressure. Later this summer I plan to push it a little further to see how close to 700rwhp I can get without pressure loss.
I may try the new Walbro 450 which flows about 10% more than the Walbro 400 at 60psi. Should be good for at least 750rwhp.
To A&A kit for ls7
