OFFICIAL A&A SUPERCHARGERS Q&A thread
#62
Something is not right. Give us a call 805-278-4107, we'll go over a few things and get that tube lined up properly.
Looks like the radiator isn't pushed down all the way. The top shroud shouldn't have a gap like that, or sit up that high. Feel free to give us a call if you have any questions.
Here's an example of how it should fit
I'll definitely give you a call. I work from my home office on Fridays, so I'll probably call you then. Is that the custom radiator in your picture, or is the stock LS3 different from the LS2?
#64
Platinum Supporting Vendor
Very NICE!!
It is! The car belongs to Brian Reckart (Reckart Performance).
It looks like the stock one. Didn't want to use a picture of one with an aftermarket radiator. Wanted to show that everything fits properly with the stock one.
You can measure the inlet of the blower. If the blower is off the car, or you remove the air bridge. A S/Si will have a 3.5" inlet, a T will have 3.75". You could also PM me the serial number and I'll look it up, or as ricefed suggested call Vortech and have them look it up.
__________________
Thanks, Josh Dodson
PLEASE TAKE A MOMENT TO VISIT OUR NEW WEBSITE AT WWW.AACORVETTE.COM
NOW PARTNERING WITH AFFIRM TO OFFER INTEREST FREE FINANCING!
A&A CORVETTE PERFORMANCE
477 LAMBERT ST Ste A
OXNARD CA 93036
(805) 278-4107
Instagram @aacorvettesuperchargers
• Facebook.com/AACorvette •
Thanks, Josh Dodson
OXNARD CA 93036
(805) 278-4107
#68
Frank I'm going to try and load a pick I want your opinion on. It's black rubber dust from my belt. The outside and sides look like new. The inside(ribbed side) looks good. First thing in the morning I have a belt squeak and now this rubber dust. Could it be a result of the belt slipping? Seems like everything is aligned fine. I have about 2600 miles on my set up. Going to load a couple pics now.
#71
#73
Yeah it just started doing this the past week. I've been having small belt chirps first thing in the morning. I tightened the belt last night. The chirp is louder but I'm sure it's because the belt is glazed from slipping. With it being tighter the boost gain was nice. I'm seeing 2 psi higher at 5k than before. What belt would you guys recommend I use when I replace it? Gatorback? Green stripe?
#75
6th Gear
ljs corvette
Can you tell me or advise me as to whether or not you can put a supercharger a stock corvette without modifing the engine? And the same question on a Z06.
#76
#78
quick question I have not seen anybody ask about the 8 rib upgrade. Any info as to what this is and how much will it change in whp numbers on a 2006 A6? Also, what should I consider if I want to do alot of WOT from a deadstop(i.e. trans, rear end, ect...)?
#79
St. Jude Donor '12-'13
If you want to do a lot of WOT from a deadstop with a SC and tires that hook, I would expect all you listed to fail at some point.
