OFFICIAL A&A SUPERCHARGERS Q&A thread
#882
Originally Posted by realcanuk
Yes. 4 inch but the supplied one was smaller. 3.5 if I remember right.
#883
Originally Posted by EnginerdVT
Ok, well if Josh can confirm, or I can measure when I'm home, then I should be ok going to a 4" pipe. I agree, if yours doesn't max out until 1000whp, then either my tables don't let me use all the MAF due to my older ecu type or something else is up.
#884
Just measured the old one. 3.5 so unless they changed things that may be what you have. It's not the ECU cause mine is a 2007, and it's not even maxed at 1000.
#885
Received 1,194 Likes
St. Jude Donor '15
And is it the frequency or airflow that is maxed out?
#886
#887
St. Jude Donor '15
Gotcha. If it's airflow then tune can be scaled a small % to get around the limit if needed without any hardware changes.
Looks like max airflow for 2008 Z06 is 512 g/sec. That's annoying, I thought it would be higher. Can be gotten around regardless though through scaling
#888
#889
Needs to upgrade to 2 bar OS.... that extends it.
#890
St. Jude Donor '15
It may clear out part of the MAF table when the upgrade is done but the tuner can copy the old table over if it does, no big deal
Really getting me worried about your current tuner to be honest
#891
It will give you blank VE tables which should be populated and tuned also.
2.5 Bar MAP - Speed Density (E38/E67 ECM)This enhancement contains the following features:
2.5 bar (255 kPa) max MAP sensor support (calibration capability for GM 0-5V linear MAP sensors)
Rescaled High MAF table supports up to 15400 Hz with 300 Hz resolution, also supports airflow up to 1024 g/sec
New VE tables with 33 x 33 cell resolution each and configurable MAP and RPM axes (choose your own resolution)
Charge Temperature based VE multiplier table, configurable axis
TPS based VE multiplier table, 33 x 17 cells with configurable TPS and RPM axes
MAP referenced "Boost Enrich" table
Boost Enrich MAP threshold and hysteresis value
Both MAF and Speed Density mode supported
Boost based fuel cut, selectable MAP threshold cuts fuel to all cylinders when exceeded
Rescaled fan temperature axis 163-250F (73-121C), stock is 192-250F (89-121C)
#892
Platinum Supporting Vendor
Yes all of our C6 kits use a 4" charge pipe like you have. Nobody tries to run a larger than 4" pipe on these cars. If you are maxing the MAF you can tune with the PE table like he did to finish it, or convert to custom OS for 2 bar setup and re-tune that way using a GM 2 bar map. But it all comes down to how your Tuner prefers to tune. Go with whichever style he is most comfortable with.
#893
Been thinking of Running E85 on my A&A Blower set up. so 60lbs injectors and BAP that come with the kit. . My Question Is, If I get the DSX Tunning Flex Fuel Sensor/Adapter, Will i need anything else other than Tunning? would like to know before I Tune it.
#894
St. Jude Donor '15
Factory pump w/BAP isn't going to be enough for E85. Injectors probably won't be enough either.
If you just mean is anything else required just to get it installed, then no.
WOT on E85 though you won't have enough fuel system, IMO.
Josh@AandASuperchargers (06-07-2017)
#895
A little help help here please Josh lol
i have a v3si, but what's this line for if it's self lubricated . Drain? Do t see anything for it on the instructions, haven't started though
#896
St. Jude Donor '15
Drain line for changing the oil.
Josh@AandASuperchargers (06-09-2017)
#898
Yes it's for oil changes so you don't make a mess draining it.
http://forums.corvetteforum.com/1583583764-post1.html
#899
Thank you sir !!
#900
Josh,
Changing the oil in my V3 today. I drained 4-oz out but after putting a little over 1/2 the new bottle in the cross hatch on the dip stick indicates it's full??
