C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Sts question
Old May 11, 2012 | 04:08 PM
carlrx7's Avatar
carlrx7
St. Jude Donor '08-'09
STS kits are especially sensitive to boost leaks and will cause all kinds of problems.
if you haven't checked for boost leaks then I can promise you have them.
seal off the turbos inlet, then remove the brake booster line. then pressurize using an air compressor, set your regulator to your max desired boost. I pressure test my TT kit to 21 psi and verify the reading on my boost gauge.
Then get a spray bottle with some soap in it and spray every single coupler, even the bov and flages. I had to tighten every clamp an additional 3 turns, and even remove the turbo compressor cover and reseal it. YES! the turbo compressor itself had massive air bubbles coming out!
then see if that cures your issue, if not, then get some SPA TURBO SEALANT, Google it and put it on every exhaust component flange (EXCEPT MANIFOLD to HEAD).
If you have STILL having issues, then change your valve springs, I personally have seen stock springs good to at least 8psi, but I run PAC-1518 springs and boost to 12psi currently.
Hope this helps!
-Carl
Old May 17, 2012 | 03:15 PM
Seadawg's Avatar
Seadawg
Hope this helps!
-Carl
If it was my car, I would want to do all the stuff I could do first, which would be to make ABSOLUTELY sure there were no leaks in the turbo system. Then, go from there.
Old Aug 26, 2012 | 11:24 AM
jlooney55's Avatar
jlooney55
Update**
Xtreme was right, valve springs
Just got them changed and installed a boost control and the car is showing some real power.
So I will apologize to Jan and xtreme...they obviously know fi...just a recommendation though, if a customer comes in and wants a tune just be happy for the business, don't bash the kit they had installed and make it seem like its going to cause nothing but problems.
Old Aug 26, 2012 | 01:22 PM
FloydSummerOf68's Avatar
FloydSummerOf68
So what kind of power is it making now that you got new valvesprings in it?
Old Aug 26, 2012 | 01:27 PM
jlooney55's Avatar
jlooney55
Not sure, but I'm assuming well over 500rwhp now. I need to get it re-tuned and dyno'd again. I'm running pretty rich at wot.
Old Aug 26, 2012 | 04:47 PM
RFZ's Avatar
RFZ
i have interest in the sts kit....my main concern is interior noise level...how is the interior noise in yours...any drone..thanks
Old Sep 3, 2012 | 11:05 AM
marjor1973's Avatar
marjor1973
For sure boost leak...
