LS3, was stock until the supercharger, 21,000 miles, BLOCKED CATS??? REALLY????
Ok I'll bite, how do you know......
Look at the picture. My car had less mileage than your when that happened. Had terrible pinging from mid to full throttle when they blocked. Im just thinking maybe in early stages the pinging might be at different RPM. I dont know if thats the problem but I would check it just to get it out off the list of possibilities. And by check I mean remove the cats and check. Its the only real way to be sure.
And were you then supercharged or otherwise modified that caused these to block? Or is this happening with stock tunes?
This happened a while after adding the eforce. It seems to be a fairly common problem on boosted cars. Like I said, since you havent even run the car with the SC much I dont know the odds of it being a problem. Im just saying its an easy thing to check, so why not get it out of the way. I dont know how your car was tuned but if a bunch of dyno pulls were done with the car rich ,or with missfires, the fuel dumped into the cats can ruin them.
I guess the correct term is "detonation", or spark knock / pre-ignition. Yes the car is 100% stock other than the supercharger. Headers are next on the list but I am glad I treaded lightly (one change at a time) so I don't have to worry about what caused the issue.
I had a new tune put in her Saturday morning (the third tune so far) and still have the issue. 3,200 to up around 3,800 to 4,000 rpm, light accelleration, detonation is heard. My speed shop is working with Chris at Edelbrock. The shop called Monday morning and have another tune for me but my schedule is prohibiting getting out to them until later in the week.
Motorhead, you have alot of experience with this set-up, what the heck is going on? Any clue?
I would look beyond the tune. Audible ping with the handheld tuner calibration is not typical.
I'd recheck the install. One possibility...Here is a photo of an install poorly executed that resulted in a crushed coil pack wiring harness resulting in misfires. I'm aware of this happening in two seperate installs at two different shops. In both cases they were professional installs executed at well known forum vendors.
Thanks for the info and sharing your experiences. Do you think I can use this as an excuse with the wife to get new cats and headers....... I'll keep you posted.
[QUOTE=Motorhead-47;1580879349]I would look beyond the tune. Audible ping with the handheld tuner calibration is not typical.
Good point Motorhead. That happened to me and I think thats what damaged my cats. Running the car while troubleshooting that problem. It took ages to find and a lot of missing going on.
I am not sure what year it changed but the new harnesses I got had plastic runners protecting the wires. The 2007 LS2 stock ones did not.
Ok so now I know of three instances of this happening! You have to strip off the plastic covers for the install. They won't fit.
When you compress air, it heats up. When you heat up air, it makes the cylinder run hotter. When the cylinders run hotter, they spit out hotter than normal EGTs(exhaust gas temperatures). When you spit out hotter than normal EGTs, the cats overheat and the precious metals cook and break. When the precious metal cooks and breaks, it looks like the picture.
Do they tail sniff new cars? or just visual inspection? You can just punch out your stock cats when you inspect them for clogging and still pass visual.
