Valve Ping with Edelbrock E Force
So, finally bit the bullet and ordered an Edelbrock 1591 kit from the local speed shop and had it installed on my 2008 2LT Z51 manual transmission car. First issue was a coolant leak from a defective intercooler resovoir, which was replaced yesterday. Cleaned the motor up last night and then went on a "spirited" drive to verify they had taken care of the leak, which is verified as fixed now. However, during my drive last night, under load, going uphill with light pedal pressure, 2,300 to 3,600 rpm, I get a noticeable valve pinging. Prior to the supercharger install, I NEVER heard a valve ping from this car. The tune is the standard Edelbrock tune as I opted for the warranty. I have called the speed shop and they are checking with service and will get back to me. Can anyone add any insight? I thought perhaps they re-flashed the ECU with a standard tune after disconnecting the battery to install the resovoir without thinking but this is only theory on my part. 95% of the time, the car runs very very good, but the valve pinging is an issue. Comments are appreciated.....
Moderator/Tech Contributor
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,831 Likes
2015 C7 of the Year Finalist
If they "stocked" you, you would have issues with the 2.5 bar map sensor, the fuel injector size and the MAF table and your car would run like crap. Sounds like a tune issue. Get your tuner to scan the car with EFILive or HPTuners and see where the ping is coming from. Ligonier PA sounds too far for a run to you!
Elmer
Elmer,
The kit came with the Edelbrock tuner. Can I "scan" the car and learn anything? Just curious, I'm sure the shop will stand behind the issue but I'd like to know as much as I can prior to taking it out to them. Thanks for the information.
What do you have to scan the car? The hand-held SCT won't scan or record. I have EFILive, I used the hand held tuner to base load a tune. My tuner than went from there and fine tuned the tune. The SCT for my '07 was a proportional tune and lied to the ECM. It caused my DIC to have some really obscene information due to the lies. We eventually loaded a stock tune, modified it (MAP, MAF, Spark, Fuel, and whatever) and that's what I use now.
My current tune is a non-proportional tune and it runs great.
Elmer
If a car with an ECU that can pull ~12* of timing is audibly pinging, you're going to get a chance to use that warranty sooner than later.
You definitely need to get it scanned to look at knock retard even if you don't tune it. Then you could email that log to edlebrock with questions and perhaps they would send you a warranty approved tune revision.
I assume you're using premium gas?
Elmer
Former Vendor
The edelbrock hand held tuner is horrible. I've retuned 3 of them,all of the cars ran 13-1 to 14-1 at WOT, knocked like a bastard(like yours) and on top of that the tune shut off P0300 - misfires .
Get someone to tune it correctly or you will try to warrenty your motor sooner or later.
Ok so I checked the tune revision in the car and it was 1.3 while the latest on the Edelbrock website is 1.4. I downloaded 1.4 onto a jump drive and took it out to the speed shop for install, since I did have a warranty with this system, I was reluctant to load the program myself. They loaded the program and I took the car out for a drive and the pinging is now WORSE than before. Technician plugged into the OB1 port and did some data logging and will send that off the Edelbrock for some technical assisitance. Anyone around Ligonier, Latrobe, Greensburg that can do a tune for me. I am starting to think that my speed shop is less than competent.
Feel free to give us a call if you want a tune that actually wont blow your car up.
Elmer
?Valve ping? I have not heard that term before. Maybe pre-ignition/spark knock?
Anyhow, I find it funny that the guys who are condemning the calibration have not even seen the car much less driven it nor logged any data. Even funnier that they all have something to sell you to fix your problem!
Is the car 100% stock other than the supercharger?
I had a new tune put in her Saturday morning (the third tune so far) and still have the issue. 3,200 to up around 3,800 to 4,000 rpm, light accelleration, detonation is heard. My speed shop is working with Chris at Edelbrock. The shop called Monday morning and have another tune for me but my schedule is prohibiting getting out to them until later in the week.
Motorhead, you have alot of experience with this set-up, what the heck is going on? Any clue?
Is this on an LS2? Just a question.
Elmer
Elmer
Check the cats. At least get that out of the realm of possibility. If they are starting to block up, that is a symptom.
Ask how I know....
Ask how I know....
