C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Torque tube
Old May 24, 2012 | 04:37 PM
05vettez51's Avatar
05vettez51
Default Torque tube
I have been getting noise when i let the clutch out in neutral in my c6. I just installed mcleod rtx clutch new zr1 t6060 and new z06 diff with hinson poly motor and trans mounts. Can my torque tube be causing this its really bothering me.
Old May 24, 2012 | 05:11 PM
PowerLabs's Avatar
PowerLabs
From: Greater Detroit Metro MI, when I'm not travelling.
Twin Disk aftermarket clutches for Corvettes are almost universally noisy. It sounds like you are hearing your floater plate rattle when there is no pressure on it. This is a common complaint: search the forum for "clutch+rattle" and see for yourself
Old May 24, 2012 | 05:28 PM
helga203's Avatar
helga203
Get a tape or recorder. Like i told you before when you push clutch in it goes away if that's the case. That's normal. Forgot is this your first aftermarket clutch??????
Old May 24, 2012 | 07:24 PM
05vettez51's Avatar
05vettez51
Yes it's my first aftermarket clutch in this car. I had a 6puck ACT clutch in a maxima when I was younger. It was a on and off clutch and drove like crap but never made a sound in neutral. But from what everyone says the sound is normal. A buddy of mine has the rst clutch with stock mounts in a c5 and not a sound. Maybe it's the Hinson mounts
Old May 24, 2012 | 08:25 PM
PowerLabs's Avatar
PowerLabs
Thats because it was a single disk. Twin disk clutches have a floater plate between the two disks and that likes to rattle.
Old May 24, 2012 | 08:42 PM
Streetk14's Avatar
Streetk14
I'd have to agree with all the responses so far. You are probably hearing the clutch rattling at idle, and those stiffer mounts probably aren't helping.
I've really never been a fan of aftermarket clutches for street cars. I can say my Katech LS9X is as quiet as my original LS7 clutch. Besides the aluminum flywheel, it's an OEM clutch setup. Driveability, pedal effort and noise are like stock. It's a great option unless you are serious about drag racing.
Old May 24, 2012 | 11:03 PM
05vettez51's Avatar
05vettez51
Thanks for all the comments. Kind of wish I went with the ls9 clutch instead of the McLeod.
To Torque tube
