C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Meth Injection
Old Jul 13, 2012 | 08:29 PM
davwar's Avatar
davwar
Default Meth Injection
Hi,
I was told today by a tuner that you cannot NOT tune for meth. He said it was a power adder and not a safety, if you run out of meth your engine is done for. I thought I had read you could run meth for safety and keeping IAT down, therefore not pulling timing? Maybe I'm just reading the methanol injection posts incorrectly?
Thanks for any insight!
Old Jul 13, 2012 | 08:38 PM
1320IN9's Avatar
1320IN9
Originally Posted by davwar
Hi,
yes you can tune for meth, you want your IAT sensor after the meth nozzle, that way you can tune it to pull timing if the IAT'S start to get high, or you can just use it for safety, but there is always a chance of pump failure, tank empty, or an electrical problem, not that bad things can always go wrong but it's possible, you may want to find a tuner who is more familiar with meth.
Old Jul 13, 2012 | 08:46 PM
davwar's Avatar
davwar
He was saying that meth is a power adder and not really for safety because if you were to run out you'd lose your engine. On kind of a side note, if I were to run out of meth and not go into boost would that be safe until I got more?
Old Jul 13, 2012 | 08:48 PM
07MontRedcp's Avatar
07MontRedcp
Here is a thread you should read. http://forums.corvetteforum.com/c6-t...lications.html
It is about using meth with a non boosted engine. You can also use meth with your boosted application in several ways. Firstly, you can tune your boosted engine without meth and then add then meth to cool the intake temperatures. That is the safe way.
The other way is to tune your engine with meth and use the IAT sensor to pull timing if you lost the meth. This is the way my car was tuned in '07. I have never been comfortable with that prospect because as your tuner says, if you loose the meth you will probably loose the engine because the IAT won't pull enough timing fast enough to save the engine. That is why I am adding a second safety backup which will monitor the meth flow and drop the engine out of boost the instant that the meth flow is outside of the normal parameters. (See the attached pdf)
Old Jul 13, 2012 | 10:04 PM
1320IN9's Avatar
1320IN9
too much to get into, read and do lots of research, meth is a wonderful thing
Old Jul 13, 2012 | 10:25 PM
NSANEC6's Avatar
NSANEC6
I think you should read and research and talk to another tuner who is more familiar with Meth... just my 02 cents which really isnt much..
Old Jul 14, 2012 | 11:32 AM
jon6.0's Avatar
jon6.0
This.
Old Jul 14, 2012 | 12:45 PM
breecher_7's Avatar
breecher_7
That tuner is a absolute moron.
Old Jul 14, 2012 | 01:02 PM
Streetk14's Avatar
Streetk14
I wouldn't call meth a 'power adder'. Unlike nitrous, the gains are minimal without any tuning changes.
There are different ways to setup a tune for meth. The best way in my opinion is to dial in a safe AFR without the meth running, then have it go rich with the meth flowing. All my cars with meth have been no leaner than 11:1 with the meth active. If the meth were to fail, it would still be in a reasonably safe zone.
Also, you should set up the IAT spark table to add any extra timing you want when the temps drop from the meth, and take it away if they go up. You don't have to do that, but it's a great way to make extra power and protect the engine.
But to answer the original question: no, you don't NEED to tune for meth. It will probably not be ideal, and overly-rich, though.
Old Jul 15, 2012 | 09:54 AM
Deezee757's Avatar
Deezee757
The only tuners that ever talk bad about meth are the ones that dont know how to tune for it, or just dont know enough about it. My $02, find another tuner!
Old Jul 15, 2012 | 04:56 PM
Le Mans Z06's Avatar
Le Mans Z06
Agreed on all the posts saying find another tuner.
Old Jul 15, 2012 | 05:52 PM
2008LS3's Avatar
2008LS3
I'm actually going to be looking for a "tuner" in Central Fl that can tune a LS3/Procharged with Meth. Hopefully one that has a lot of experience with this application.
Old Jul 15, 2012 | 06:10 PM
davwar's Avatar
davwar
Does anyone have any tuner recommendations regarding meth in the Bay Area (CA)?
Old Jul 15, 2012 | 06:55 PM
BLACK-10's Avatar
BLACK-10
wow! find another tuner fast!
Old Sep 26, 2012 | 01:03 AM
chasmania's Avatar
chasmania
1st Gear
You should check Monster Motorsports inc. in Davie, fl out. They've had some awesome experience and the kits can be installed stealth or not. Pm me for more info.
Old Sep 26, 2012 | 08:58 AM
helga203's Avatar
helga203
Hi,
Was it the dumba$$'s in schaumburg,IL if so get your car out of there as fast as possible.
Old Sep 26, 2012 | 09:00 AM
Flash20's Avatar
Flash20
To Meth Injection
Old Sep 26, 2012 | 10:39 AM
ShaneFap's Avatar
ShaneFap
I ran meth for over a year on my 10 second G8 i absolutely loved it.
Little boost of octane of course, cooler IATs, and a little more timing(only added timing depending on certain IAT temps) that way if the meth didn't work or failed the extra timing would not be added.
Alky Control i had was also top notch!
Old Sep 26, 2012 | 01:28 PM
breecher_7's Avatar
breecher_7
I think i know who you are referring to....
Old Sep 26, 2012 | 01:47 PM
DSteck's Avatar
DSteck
I've ran my meth tank completely dry. When moving over 100 lb/min of airflow, things can go wrong really fast. Even when the tank is dry, my engine still hasn't popped. There are different ways to tune and compensate for the meth. It is entirely possible to tune a car to work if the meth fails while still having a benefit from it spraying. I wouldn't call meth a power adder... just a power enabler.
