C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Black Intercooler
Old Dec 4, 2012 | 06:54 PM
greerracing's Avatar
greerracing
Default Black Intercooler
Im putting my car back together and was wondering if it would raise iats if i painted my intercooler black with radiator paint.
Old Dec 4, 2012 | 07:17 PM
madmax4499's Avatar
madmax4499
NOPE! it will look bad after a while. some shops sell anodized intercoolers.
Old Dec 4, 2012 | 07:38 PM
Unreal's Avatar
Unreal
I know my friends at the turbo shop have a special heat disappaiting coating they do on the intercoolers that is black. It is very cool looking. Needs to be a new IC though because once they get oil/etc on them it won't stick and is too much of a pain to clean to get it to work.
Old Dec 4, 2012 | 07:39 PM
BoosterClub's Avatar
BoosterClub
Anodizing is the best way to go, most durable. Paint chips off easy.
Old Dec 4, 2012 | 07:48 PM
Skunkworks's Avatar
Skunkworks
Go black anodized don't paint, got it on my car. Helps thermal transfer too, not sure it’s a measurable amount on typical application. Get a shop that knows what they are doing as to not leave acid inside…
Old Dec 4, 2012 | 07:52 PM
BoosterClub
Doesn't help, if anything it insulates, but does prevent oxidation.
Old Dec 4, 2012 | 07:55 PM
greerracing
I might get it annodized if it wont take to long. I don't wanna hold up my rebuild to much. The rest of my kit is hidden so i thought id try to hide my ic.
Old Dec 4, 2012 | 08:03 PM
Skunkworks's Avatar
Skunkworks
Anodizing is not an insulator, it does enhance thermal transfer a bit… Google aluminum with different treatments. Also Bell intercoolers does a mild natural anodizing on higher end cores.
Old Dec 4, 2012 | 08:09 PM
inspector12's Avatar
inspector12
The right stuff is the stuff they use on the A/C condencers comes in a spray can looks like bumper black when sprayed etc... No real ill effects GL!
Old Dec 4, 2012 | 08:10 PM
Skunkworks's Avatar
Skunkworks
Mine was one day, think $125 with other parts.
Old Dec 4, 2012 | 08:26 PM
BoosterClub
Take your own advice and google it. Not about to argue with you in someone elses thread.
Old Dec 4, 2012 | 09:35 PM
SinisterC6's Avatar
SinisterC6
Speedy
2024 C8 of the Year Finalist - Modified
No problems here, I went the extra mile and masked off all the fins before spraying
My paint didnt chip but I did a lot of prep
Old Dec 5, 2012 | 09:51 AM
greerracing
Thanks for all the help guys. If i can find an annodizer i might try that or i might try to find the condensor paint.
Old Dec 5, 2012 | 10:23 AM
backchannel's Avatar
backchannel
Skunkworks is right
Anodizing improves emissivitity over bare aluminum whether it is dyed or not.
Old Dec 5, 2012 | 11:38 PM
zwaldo's Avatar
zwaldo
out of curiosity...do you think that the duplicolor metal cast paint would work for him? anyone ever use this?
http://www.duplicolor.com/products/metalCast/
Old Dec 6, 2012 | 12:18 AM
BoosterClub
Originally Posted by backchannel
Skunkworks is right
Emissivity is radiant heat transfer, this is not what you should be looking at, unless you stuck your intercooler in your trunk and are expecting it to operate in a passive manner, in which case yea, that's what you should be concerned about.
Otherwise you should be concerned with it's conductivity, which is lowered with anodizing. But the simple fact is the difference is insignificant which is where the "if anything" comes in.
To Black Intercooler
