C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
need help..... code P2135
Old Dec 5, 2012 | 06:45 PM
07blkvette's Avatar
07blkvette
Default need help..... code P2135
A friend of my has a 2007 ctsv with maggie 112 installed. After about 500 600 miles of driving after maggie install code P2135 came up, replaced throttle body, pedal assembly still keeps coming on. Could anyone shed some light on what else it could be.
Old Dec 5, 2012 | 08:24 PM
Deezee757's Avatar
Deezee757
Is it going into limp mode? Could be the PCM. (Ive seen this before, not on my vette though) My first guess would have been the pedal switch as well. My car had one fail when it was stock. First 1k miles. dealer replaced it and it was fine. Doing homework online before I took it too them I found that, the throttle body, or the PCM. Who did the install/tune. Id talk to them first.
Old Dec 5, 2012 | 11:43 PM
cranky's Avatar
cranky
replace the connector on the throttle body. the wires brake internally causing this code. solder and shrink all wire connections. this is a fairly common problem among gm vehicles. they may have gotten damaged during the install of the maggie. good luck
Old Dec 6, 2012 | 11:48 AM
Austin-vette's Avatar
Austin-vette
St. Jude Donor '08
I may have a similar problem, where can I get the electrical connector without buying the entire harness? Thanks.
To need help..... code P2135
