C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Procharger problems
Old Dec 11, 2012 | 02:46 AM
06prochargedVette's Avatar
06prochargedVette
Default Procharger problems
Does anyone else have problems with their Procharger making a squeaking sound? It sounds like the belt on the pulley, but I have replaced it (the belt) and it stills squeaks. Any suggestions? Also, if anyone could send me a link on how to change the oil in the Procharger, it would be greatly appreciated.
Old Dec 11, 2012 | 07:32 AM
EuroRod's Avatar
EuroRod
Check alignment of the pulleys. Do you notice a lot of black belt dust? If the pulley's are aligned, switch to a GoodYear Gator back belt and make sure it is tensioned properly.
Old Dec 11, 2012 | 08:13 AM
1320IN9's Avatar
1320IN9
Do you have a quiet or "noisy" head unit? The head units that whistle may be what you hear but also make it harder to pinpoint the problem.
Old Dec 11, 2012 | 08:15 AM
4evervette's Avatar
4evervette
it could be a bad tensionner ..
Old Dec 11, 2012 | 11:11 AM
Matt @ FSP's Avatar
Matt @ FSP
St. Jude Donor '13
As Greg pointed out, the Prochargers are loud (Sound great IMO) and sometimes harder to isolate a noise. A stethoscope may help you isolate the noise. Other thing you can do is run it with no belt, just to make sure the noises are not coming from the blower. The tensioner could be shot as 4ever had suggested also.
As per the oil change directions. You will see a drain plug on the bottom of the unit, just about opposite your fill plug/dipstick. I'd let it drain for a bit if the car is cold to get all of the oil out of it. Then remove your top fill plug/dipstick and fill the unit. Pay attention to the bottom hashmarks on the dipstick, I try to keep most of them in the half to 3/4 range. Do you have the Procharger oil? If not pick some of that up that's what Procharger recommends and I'm sure is necessary for any warranty issues.
Matt
Old Dec 11, 2012 | 02:21 PM
06prochargedVette
Thanks guys. It sounds more like what Euro said. I do notice alot of black belt dust. I actually just got done cleaning the engine bay. I really appreciate it. And I appreciate it Matt.
Thanks again for the suggestions.
Old Dec 11, 2012 | 02:39 PM
Drewstein's Avatar
Drewstein
If you think it's a pulley, take about 12" of stock fuel hose and stick one end in your ear and use the other to listen to specific pulleys. I have found a few bad pulleys this way.
Old Dec 11, 2012 | 10:07 PM
06prochargedVette
Thanks again guys. Here's some pictures of the setup. Looking to do more to the engine. Not real sure what my plans are yet.
Old Dec 11, 2012 | 11:17 PM
Andy@A&ACorvette's Avatar
Andy@A&ACorvette
Platinum Supporting Vendor
Get a spray bottle and spray a shot of water on the inside of the belt. If the noise quits immediately, it's a belt issue. Try the same on the outside of the belt.
If neither makes the noise quit, then it's a pulley or the blower.
The noise will come back right away but it will immediately identify the noise as belt related or bearing related.
__________________
PLEASE TAKE A MOMENT TO VISIT OUR WEBSITE AT WWW.AACORVETTE.COM
NOW PARTNERING WITH AFFIRM TO OFFER INTEREST FREE FINANCING!
ANDY GREEN- OWNER/ CEO -A&A CORVETTE / A&A SUPERCHARGERS
477 LAMBERT ST
OXNARD CA 93036
WWW.AACorvette.com
A&A CORVETTE SUPERCHARGER SYSTEMS
HOME OF THE WORLDS FIRST
CENTRIFUGALLY SUPERCHARGED C7
SUPERIOR ENGINEERING- SUPERIOR POWER
SUPERIOR PRICING- SUPERIOR CUSTOMER SUPPORT
Andy@AACorvette.com 805- 278 4107
Old Dec 11, 2012 | 11:26 PM
06prochargedVette
Alright, I will try it as soon as I get home. What if its not the belt? Would it be okay to continue to run it? What would I be losing?
Old Dec 12, 2012 | 12:42 PM
Drewstein's Avatar
Drewstein
If it's a pulley you can run it for a bit, but you will risk the chance of it seizing eventually.
Depending on the pulley you can replace it within 24 hours.
Old Dec 12, 2012 | 01:25 PM
blkscls1z's Avatar
blkscls1z
Is the tensioner aligned properly? A new belt will stretch and it will need to be adjusted after 100 miles or so.
Old Dec 25, 2012 | 08:57 PM
Nasser_q8's Avatar
Nasser_q8
i've got the same problem last year what i found is my timing cover is leaking oil and it drops to the harmonic balancer that what cuase the slipping and the squeaking sound , what i suggest you to do check the timing cover seal. good luck
To Procharger problems
