C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Fast ?
Old Feb 16, 2013 | 05:44 PM
revo1059's Avatar
revo1059
St. Jude Donor '11
Default Fast ?
My 06 (A6) has a blower cam in it and an A&A V3 kit waiting to be installed. I still have the stock intake. Is a FAST worth the $1000 with installing the S/C? When I do this I want to do it once and be done, but if the gains aren't there then I don't want to waste $.
Old Feb 16, 2013 | 05:55 PM
saplumr's Avatar
saplumr
I originally had a FAST 90 when the blower was put on 7 years ago. When the boost was turned up the FAST was removed due to no burst panels. Looking back I wish I would have put on another. Probably 20-25hp gains.
Old Feb 16, 2013 | 06:55 PM
EuroRod's Avatar
EuroRod
I feared the same burst issue when I installed my ProCharger 6 years ago, so I installed a Performance Products Typhoon aluminum intake. The only complaint I might have is that it does retain heat more than a plastic manifold. But, it will never burst!
Old Feb 16, 2013 | 07:02 PM
saplumr's Avatar
saplumr
Originally Posted by EuroRod
That's a good look!
Old Feb 16, 2013 | 07:26 PM
carlrx7's Avatar
carlrx7
St. Jude Donor '08-'09
depending on what fast 90/92/102? there may be issues with the fitment of the a&a bracket.
i had an A&A with a 92, and had to make a custom p/s res bracket and flip the tb and extend its harness.
-Carl
Old Feb 16, 2013 | 07:45 PM
saplumr's Avatar
saplumr
I used a Trailblazer SS tb.
Old Feb 16, 2013 | 07:57 PM
TRINIC5's Avatar
TRINIC5
I had a Procharger with a Fast 102, nothing but problems I had with it, I called Fast and they replaced it 3 times, well I sold the third one new in the original box for half price.
With forced induction the most important factor is strength, its forced induction so it will flow through almost anything with a good enough flow, like stock. I am presently running the stock intake and is making 816rwhp on my C6 and on my C5 I am running the LS6 intake and is making 914 RWHP through a 4L80E and all these numbers are on a Mustang Dyno.
Old Feb 16, 2013 | 09:59 PM
SHovV's Avatar
SHovV
Iirc, FAST manifolds are pressure tested to 30+ psi
Old Feb 16, 2013 | 10:12 PM
revo1059's Avatar
revo1059
St. Jude Donor '11
Which FAST would be the best bet (LS2)?
Old Feb 16, 2013 | 10:18 PM
saplumr's Avatar
saplumr
Burst panels are necessary to reduce damage in case of backfire.
Old Feb 16, 2013 | 10:28 PM
saplumr's Avatar
saplumr
Might as well get the 102.
Old Feb 17, 2013 | 09:18 AM
revo1059's Avatar
revo1059
St. Jude Donor '11
So are the gains in my setup worth spending the $ on a FAST 102?
Old Feb 17, 2013 | 10:38 AM
helga203's Avatar
helga203
If your looking for every bit of hp then yes.10 here 5 there adds up. As long as your family is not starving like mine.
To Fast ?
