That "little" Si Trim is awsome.
Platinum Supporting Vendor
I spend a lot of time trying to talk customers out of upgrades, rather than into them. I see a lot of threads where people suggest that when buying an A&A system they should upgrade to a larger head unit.
I am, and always have been, a big proponent of using the correct head unit for the application. Buying a larger head unit and then putting a big pulley on it is just inefficient.
This dyno chart is of my own car. Bone stock vs. an A&A Si trim (3.4 pulley) a medium cam and ARH headers. I think this is a very common combination that a lot of guys would be willing to do.
I am spraying some Methanol on top but it's not a totally Methanol dependent tune. It made 719 on 93 Octane and no Methanol.
What advantage would I have by putting on a bigger (more expensive) blower and slowing it down so as not to kill the engine? None that I see.
The gains, as low as 2500 RPM, are huge and just get larger from there.
I just thought some of you would find this interesting.
__________________
PLEASE TAKE A MOMENT TO VISIT OUR WEBSITE AT WWW.AACORVETTE.COM
NOW PARTNERING WITH AFFIRM TO OFFER INTEREST FREE FINANCING!
A&A CORVETTE
477 LAMBERT ST
OXNARD CA 93036
WWW.AACorvette.com
A&A CORVETTE SUPERCHARGER SYSTEMS
HOME OF THE WORLDS FIRST
CENTRIFUGALLY SUPERCHARGED C7
SUPERIOR ENGINEERING- SUPERIOR POWER
SUPERIOR PRICING- SUPERIOR CUSTOMER SUPPORT
Andy@AACorvette.com 805- 278 4107
A&A CORVETTE
477 LAMBERT ST
OXNARD CA 93036
WWW.AACorvette.com
I'm also curious how hard the Si can be spun ?
If you spin your LS7/Si combo to 7k with a 3.4" pulley... then maybe I can drop to a smaller pulley size on my LS2 ? Say... 3.25" and spin it to 6500 ?
I have a LS3 MAF conversion and 2nd meth nozzle to add also.
Two M15 nozzles at full-blast is definitely "meth dependent"
Cool. Thanks. I was going to put the 3.4 I have on my LS3 T-trim, but I think I will order the 3.6 first. At least until I upgrade the clutch. I'm at 578/511 on 7psi using E85. 6500rpm redline.
About what I would expect on that setup. I made right under 700rwhp with a ZR1 cam on the SI with a 3.6 pulley. A little more boost and a blower cam and I would have expected to see low 700's. Still a good blower for a street car and not looking to make big numbers.
What are your cam specs Andy?
That is awesome that you are getting so much power out of it. I know I spoke to you guys about running a 3.6" pulley on my Si cammed LS2, but my tuner is really fighting me on it. They want to go with the 3.8" for a more conservative tune even though I am running e85.
What size motor, compression & boost?
Get a new tuner. I'm on E85 also. Mine wants me to pulley down as the 3.8 only gave me 7psi at 6300rpm. I still want to run 91 octane when I go out of town, so he wants me to stay 10-11psi so the timing isn't retarded low when I'm on 91. So I'm taking my 3.8 off and doing a 3.6 pulley. Heck, if all I ran it on was E85 I would use the 3.4 pulley I have. I still might when I do a better clutch.
I've seen Si, T, and Ysi headunits over-spun to get more power out of them, but you proceed at your own risk at that point, lol.
__________________
Thanks, Josh Dodson
PLEASE TAKE A MOMENT TO VISIT OUR NEW WEBSITE AT WWW.AACORVETTE.COM
A&A CORVETTE PERFORMANCE
477 LAMBERT ST Ste A
OXNARD CA 93036
(805) 278-4107
Instagram @aacorvettesuperchargers
• Facebook.com/AACorvette •
Thanks, Josh Dodson
OXNARD CA 93036
(805) 278-4107
