C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Harmonic balancer replacement when sc
Old May 6, 2013 | 08:00 PM
07blkvette's Avatar
07blkvette
Default Harmonic balancer replacement when sc
What options other than oem would be the best replacement for HB when SC?
Old Jun 17, 2014 | 05:57 PM
Jharms's Avatar
Jharms
Default Harmonic Balancer when supercharged
I'm doing a search for this same information. Is there a better alternative than going back stock?
Old Jun 17, 2014 | 06:01 PM
Unreal's Avatar
Unreal
IW, get an OD one to help with belt wrap and slip, and go 8 or 10 rib right away so later on it is a cheap/easy upgrade if you update later.
Old Jun 17, 2014 | 09:33 PM
1sc334's Avatar
1sc334
Agreed...had no luck with stock balancer may as well do it same time as install...plus 1 for IW BALANCER!!!
Old Jun 18, 2014 | 02:45 AM
turbotuner20v's Avatar
turbotuner20v
Ati is an option too. I'm trying their 10-rib 6% overdrive
Old Jun 18, 2014 | 03:11 AM
jon6.0's Avatar
jon6.0
ATI also has an Ebay store where they sell cosmetically blemish pulleys for cheap. I got mine for $220.
Old Jun 18, 2014 | 06:13 AM
turboffr's Avatar
turboffr
St. Jude Donor '10
Same here. Best deal around.
Old Jun 18, 2014 | 08:21 AM
Unreal's Avatar
Unreal
I would still pay extra for the IW just for the ability to run the cog direct drive or 6 rib zr1, and their customer service/support is top notch.
Old Jun 18, 2014 | 12:14 PM
Pitufina's Avatar
Pitufina
Other options are the Summit C2501 or Trick Flow 19005. Both are SFI rated. Currently I have the Summit underdrive version installed, but bought to the TFS now that I'm going FI. IMO you can't buy a better balancer for the price.
Old Jun 21, 2014 | 04:47 PM
ravill's Avatar
ravill
I went with an ATI unit when I s/c'd my vette.
It is like a piece of jewelry.
Be a little careful about undersized pulleys as this can cause your lights to dim at idle or other weird things, I've read.
Old Jun 21, 2014 | 09:55 PM
vforrest's Avatar
vforrest
Same one...
Old Jun 22, 2014 | 07:18 PM
SlayerRX8's Avatar
SlayerRX8
I went with an 8-rib ATI balancer in preparation for a blower later.
To Harmonic balancer replacement when sc
