C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Best radiator
Old Oct 6, 2013 | 01:25 PM
colts95ta's Avatar
colts95ta
Default Best radiator
I am not looking to start a debate. Simply Just which one would best suite my needs.
The Car is a 07 Z06. I have a mild blower camshaft,Reher morrison heads, 2" ceramic coated headers,meth, full dual 3" ceramic coated exhaust, paxton 1500SL with A&A intercooler and A/C in still in tact.
Around 750 RWHP.
I live in OK. Just had a few issues getting warm over the summer with the A/C on while sitting in traffic. I have read many reviews about different radiators/ways to cool it. I just did the camshaft and I do not want to go back with the stock radiator since its already out. I also will be switching the coolant to evans Coolant. It is supposed to drop around ~15° according to Hinson Motorsports. Fingers crossed
Some people indicate that thicker radiators are hard to pull air through and will still heatsoak it just takes longer.
Second, The factory oil cooler is no longer able to be mounted in front of that radiator. I had it mounted behind the fan. Just seems like a bad place to try to cool anything...
Please advise with one any of you guys are running that have done this in the Hot part of the country.
Thanks Colt
Old Oct 6, 2013 | 01:43 PM
erick_e's Avatar
erick_e
St. Jude Donor '13-'14-'15-'16
I have an E-Force and I installed the DeWitts ZR1 style radiator. Even with the condensor and intercooler in front of it I never exceed 225 in the hot NC summer while sitting in traffic.
I also heard good things about the RSD radiator..
Old Oct 6, 2013 | 02:01 PM
colts95ta's Avatar
colts95ta
Thanks.
What is the difference between the ZR1 radiator?
Does it have a oil cooler inside?
Yeah I have read some good about the RSD one too. The one cut is cool for the higher HP cars.
Old Oct 6, 2013 | 02:09 PM
erick_e's Avatar
erick_e
Originally Posted by colts95ta
Thanks.
The ZR1 radiator has the inlet port for the ZR1/LS9 style oil cooler.
Old Oct 6, 2013 | 06:13 PM
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
I also will be switching the coolant to evans Coolant. It is supposed to drop around ~15° according to Hinson Motorsports. Thanks Colt
Colt, you should read the information on Evans from thier website. It will tell you the exact opposite because of the waterless formula, the Evans will actually raise the temperature.
and of course I think the DeWitts radiator is the better choice. Why?
Because we make them, in house, including our own epoxy free cores.
We are so confident in the product, we warranty them for as long as you own the car.
Old Oct 6, 2013 | 07:01 PM
bosco 08's Avatar
bosco 08
Evans FAQ. Interesting stuff.
http://www.evanscooling.co.za/faqs.html
Old Oct 6, 2013 | 07:49 PM
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
There you have it
"Evans has a boiling point above 180ºC which ensures it will not boil or turn to vapour inside an engine. By remaining as a liquid under all engine loads effective heat transfer is maintained. Engines filled with Evans usually run 3 - 10ºC hotter than those using water-based coolants, but the overall heat transfer and engine efficiency is improved through the elimination of steam-vapour pockets. The lube-oil temperature also runs 3 – 10ºC hotter with Evans but >500,000 successful conversions confirm this has no detrimental effect."
82C = 180 92c =200f (so could be 20 f more)
Old Oct 6, 2013 | 08:27 PM
colts95ta's Avatar
colts95ta
PM me a price for your setup. Thanks
Old Oct 7, 2013 | 07:27 AM
colts95ta's Avatar
colts95ta
Thanks for the advise. I will probably just run antifreeze and distilled water. Maybe I will try the evans in my tractor
Old Oct 7, 2013 | 07:57 AM
jon6.0's Avatar
jon6.0
I'm at 719rwhp and I use a stock radiator with stock fans. A&A blower kit. I use pure water in the summer with a bottle of Amsoil Coolant Boost. Now that the weather is cooling down I'll throw a little antifreeze in there. Then next summer go back to pure water. Pure water made a 10F-15F drop in temps for me.
Old Oct 9, 2013 | 02:23 PM
Mambo_Vette's Avatar
Mambo_Vette
Originally Posted by jon6.0
i'm at 719rwhp and i use a stock radiator with stock fans. A&a blower kit. I use pure water in the summer with a bottle of amsoil coolant boost. Now that the weather is cooling down i'll throw a little antifreeze in there. Then next summer go back to pure water. Pure water made a 10f-15f drop in temps for me.
z06??
Old Oct 9, 2013 | 02:24 PM
Mambo_Vette
z06?
Old Oct 9, 2013 | 02:48 PM
Mike Farris's Avatar
Mike Farris
His sig says 1LT coupe. So, not a Z06.
I am impressed his radiator keeps up in Arizona heat. Well sorted car I'd say.
Old Oct 9, 2013 | 04:18 PM
Mambo_Vette
Anyone here has the A&A SC in a Z06 with the factory radiator? Work if you relocated the oil cooler out?
Thank
Old Oct 18, 2013 | 05:15 PM
ravill's Avatar
ravill
I've got a GS. I had to install the DeWitts.
Beautiful unit. Here are some comparison shots.
I still had hot temps and my AC would shut off in hot california traffic.
I fixed it by adding an 8" fan infront of my condensor on the driver side of the intake. Now, I barely make it over 200 with the a/c on while sitting in traffic.
Old Oct 18, 2013 | 06:57 PM
TRINIC5's Avatar
TRINIC5
Pure water also cause corrosion
Old Oct 18, 2013 | 07:52 PM
colts95ta's Avatar
colts95ta
When you put the 8" fan in there, are you pulling air or pushing air?
To Best radiator
Old Oct 19, 2013 | 12:22 PM
TRINIC5's Avatar
TRINIC5
I believe he is pushing the air through the radiator which now helps keep the heat down in the condenser while sitting in traffic on a very hot day. If the AC condenser don't get very hot the AC will continue to blow cold.
Old Oct 22, 2013 | 07:39 PM
ravill's Avatar
ravill
That is correct, I'm pushing air with this 8" fan. So far, so good!
Old Oct 30, 2013 | 09:19 PM
EuroRod's Avatar
EuroRod
I've had both a Ron Davis and a DeWitts radiator in my ProCharged C6.
I had nothing but trouble from day one with the Ron Davis. It never stopped leaking from the EOC supply and return line ports. Could never get any assistance from the manufacturer either.
The DeWitts is a complete different story. Great quality. No leaks.
My setup uses their drop in radiator with EOC and stock fans, a Meziere EWP and 160 t'stat.
Summer temps in 100 degree heat are coolant 205 and oil 215......... max.
DeWitts rock the house!
