C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Best radiator
Old Oct 30, 2013 | 09:33 PM
colts95ta's Avatar
colts95ta
Originally Posted by EuroRod
I've had both a Ron Davis and a DeWitts radiator in my ProCharged C6.
I had nothing but trouble from day one with the Ron Davis. It never stopped leaking from the EOC supply and return line ports. Could never get any assistance from the manufacturer either.
The DeWitts is a complete different story. Great quality. No leaks.
My setup uses their drop in radiator with EOC and stock fans, a Meziere EWP and 160 t'stat.
Summer temps in 100 degree heat are coolant 205 and oil 215......... max.
DeWitts rock the house!
I considered the EWP... How do they work when you are out on the highway pulling on it? Like 3rd and 4th gear at 6500 RPM. My take on it was they are great for in town driving but not as good for Highway pulls.. Ive never done a EWP on the street. Thanks for your input. 205 in the 100° days is good.
Old Nov 3, 2013 | 04:47 PM
lurch59's Avatar
lurch59
Originally Posted by Tom DeWitt
There you have it
"Evans has a boiling point above 180ºC which ensures it will not boil or turn to vapour inside an engine. By remaining as a liquid under all engine loads effective heat transfer is maintained. Engines filled with Evans usually run 3 - 10ºC hotter than those using water-based coolants, but the overall heat transfer and engine efficiency is improved through the elimination of steam-vapour pockets. The lube-oil temperature also runs 3 – 10ºC hotter with Evans but >500,000 successful conversions confirm this has no detrimental effect."
82C = 180 92c =200f (so could be 20 f more)
So are you saying you don't recommend Evans? In theory the hot spots in the combustion chamber cause spontaneous combustion from the cylinder pressure rise immediately followed by spark plug ignition resulting in collision of flame fronts and poor flame front travel.
I'm installing a DeWitts radiator in my 69 bbc 496, aluminum heads, approx 690 hp. It's a stick with A/C, do you think I will over heat?
Old Nov 3, 2013 | 07:02 PM
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
Everything I have read about Evans suggests that it is a good product. I know that it is expensive, will run a little hotter, and you shouldn't mix it with other coolants or water.
When it comes to coolants, my recommendation is to keep it simple. Buy a brand name, pre-mixed, five year coolant. This way you don't have to try to figure out a water/coolant ratio and there is no risk of getting minerals from poor water. If it gets low or you blow a hose, just can top it off right from the bottle and again you don't have to worry about changing the ratio. Even if you are in the middle of nowhere, the local gas station with have some.
Old Nov 5, 2013 | 08:06 AM
Six-Gun-Todd's Avatar
Six-Gun-Todd
IMO....all the shrouds that come with the centri kits are worthless
I went with a Dewitt's radiator and Spal fan package which helped some...but I think where the real problem lies is in the huge gaps around the shroud. No matter how big the radiator or fan package if all you are doing is recirculating hot air from the engine compartment then you aren't cooling efficiently.
Old Nov 5, 2013 | 09:47 AM
lurch59's Avatar
lurch59
I wonder how much a hood scoop helps by leaving a space for the hot air to escape. Anyone have a before and after story of temps decreasing after installing the L88 style hood?
Old Nov 5, 2013 | 10:43 AM
Unreal's Avatar
Unreal
I'm doing a vented hood this week. I've heard 12-20F difference with a vented hood. I'll report in.
I got a dewitts. It works good but I wish I did the shorter version for the supercharger intake. I may sell it and swap one day. The one I have is the full EOC/TOC one. I'm running an external oil cooler so that part is wasted too.
Old Nov 25, 2013 | 03:23 PM
K B Vettin's Avatar
K B Vettin
Default zr1 mufflers
Colt, you should read the information on Evans from thier website. It will tell you the exact opposite because of the waterless formula, the Evans will actually raise the temperature.
and of course I think the DeWitts radiator is the better choice. Why?
Because we make them, in house, including our own epoxy free cores.
We are so confident in the product, we warranty them for as long as you own the car.
Hi Tom,
I recently ordered a ZR1 radiator from your website and returned it because I thought i was going to go with a vented hood to reduce engine temps and have decided to keep the stock hood and upgrade the radiator. Do you offer discounts to forum members? i have a heavily modded 2013 ZR1 with 700 WHP running 16lbs of boost. i have the 160 degree thermostat and my temps were in the 180's 190's, but when i upgraded the heat exchanger my IAT2 temps dropped but my engine temps went up about 15 degrees. i know the thicker katech heat exchanger is blocking some flow, I've looked at LG and Ron Davis. any advice and or discount would be greatly appreciated.
Kris
Old Nov 25, 2013 | 06:39 PM
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
Originally Posted by kristopherbush
Hi Tom,
Kris
If you can wait, we have our annual sale in January each year.
Old Nov 25, 2013 | 11:32 PM
K B Vettin's Avatar
K B Vettin
i have a track day on 12/28, I would like to install by then. what type of discounts do y'all offer in Jan?
Old Nov 26, 2013 | 08:39 AM
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
It's usually something around 15%. Summit Racing is offering free shipping right now. You could also check with Ecklers or Corvette Central. Both offer specials and discounts
Old Nov 26, 2013 | 10:25 AM
Unreal's Avatar
Unreal
Matt@FSP also has very attractive pricing.
Old Nov 26, 2013 | 11:04 AM
shizon'00's Avatar
shizon'00
The EOC in the DeWitts doesn't come with the GM fittings right? Anyone know the part number?
Old Nov 26, 2013 | 11:10 AM
  #33
Unreal's Avatar
Unreal
I don't think there is a part number, they are part of the oil cooler and have to be removed from there. At least that is how it was when I bought them. I may have a set laying around if I look around since I swapped to custom built AN lines.
Old Nov 26, 2013 | 11:33 AM
  #34
shizon'00's Avatar
shizon'00
When searching I found a few posts that said you could get them from GM, but didn't have a part number. I haven't been able to find one though so you could be correct.
I still have my OEM radiator so I'll try to pull those and swap them over to the DeWitts.
Old Nov 26, 2013 | 12:27 PM
  #35
K B Vettin's Avatar
K B Vettin
i looked on Summit's website and they didn't list on specific to the ZR1, they had everyother model. is the ZR1 version specific or do other model numbers fit? below is from your website.
Model: 1139109Z
Our new radiator for 2009-2012 ZR1 option Corvettes. This radiator is also used on 2012 Z06 with special Z07 option.
Old Nov 26, 2013 | 12:30 PM
  #36
K B Vettin's Avatar
K B Vettin
found it i tpyed in the part number and it came up, but it says it won't ship until 12/13.
tom do you have a ZR1 radiator in stock ready to ship today?
Old Nov 26, 2013 | 12:34 PM
  #37
smurfkiller's Avatar
smurfkiller
dewitts
To Best radiator
Old Dec 13, 2013 | 11:53 PM
  #38
K B Vettin's Avatar
K B Vettin
Tom--i received the radiator and my car is sitting at the dealership because i believe i was sent the wrong radiator. I hate to contact you in a public format but i need a answer as soon as possible and your shop is closed tomorrow. my question is; is the ZR1 radiator a direct fit or does the surge tank inlet hose need to modified? My dealership is doing the install and i have pictures of the issue which is the air bleed pipe on the radiator i was sent is pointing straight out when it should point up at a 45 degree angle as the stock pipe does. the dealership says this is the fit of the LS3/7 not the LS9. please call me if you can 619.300.9032.
Kris
Old Dec 14, 2013 | 07:25 AM
  #39
erick_e's Avatar
erick_e
St. Jude Donor '13-'14-'15-'16
Kris
Not sure if this will help you, but here is a picture of my DeWitts ZR1 radiator.
Old Dec 14, 2013 | 07:44 AM
  #40
K B Vettin's Avatar
K B Vettin
That helps tremendously. They did send the wrong one. You see how air bleed pipe is pointing to 10 o'clock, on the one the sent me it points straight out and the surge tank inlet hose won't connect. It would have to be cut and have extra hose clamped on to make it fit, which i refuse to do. Thanks again, I hope they have one in stock that they can ship over night. I wonder what they are going to do to help me with the extra labor I'm going to charged because of this mistake....
