C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Lean dyno.
Old May 19, 2013 | 05:39 PM
JMBLOWNWS6's Avatar
JMBLOWNWS6
Originally Posted by OBSSSD
I agree with your assessment and by first looking at the file this would tell an experienced tuner right away if it was actually the problem. I was telling the OP to have someone set the P/E table pig rich to eliminate the tune possibility and then if there was no change richer then look to the fueling side - specifically the stock pump or the BAP.
BUT...
It is impossible that the problem has anything to do with the change from Florida air to Texas air. I know this for a fact from lots and lots of experience both personal and from tuning out of state cars. And I'm not saying that you said this because I wasn't there and have no idea, but if you did then that is what I am referring to with my comment.
With boosted cars going lean the most common problem I have seen is usually a fueling issue, because even a dumb tuner can set the P/E table value high enough to get the A/F ratio in the high 11's before the car leaves his shop.
Sorry Chris we dont PE rape cars. We go over them not just make hits on the dyno. Not like you did to my trans am.
Old May 19, 2013 | 07:23 PM
OBSSSD's Avatar
OBSSSD
Originally Posted by helga203
Just curious if this is SD tune will adjusting P/E table do anything with AFR??????
Don't you have to copy paste the VE table to adjust AFR????
Most people prefer to MAF tune the newer cars since they don't actually have a VE table. Personally myself I find straight MAF tuning gives the best throttle response while still maximizing power, and the car adjusts nicely to changes in temperature and climate without touching the tune.
My point still stands that to see if you have a fueling problem you command a lot more fuel and see if the A/F ratio changes on the dyno. Whether you increase VE at WOT (if there is a VE table) or raise the PE ratio it is simply a diagnostic test to see if you have a fueling issue or not. How you command the extra fuel makes no difference really.
Nice try but sorry wrong tuner - perhaps you have me confused with Chris from AMS back in the day who blew up LS1's for fun by completely disabling the knock retard ability of the PCM.
Maybe that crazy Texas air that's messing up tunes has gone to your head
Old May 19, 2013 | 07:28 PM
JMBLOWNWS6's Avatar
JMBLOWNWS6
Im pretty sure you use to do tunes for RPM. To be exact Chris Robinson.
Old May 20, 2013 | 02:25 AM
LethalTT's Avatar
LethalTT
Ouch...
Old May 21, 2013 | 01:28 AM
OBSSSD's Avatar
OBSSSD
Well since I have never "raped" a PE table in my life if your car had that done to it then it wasn't tuned by me. RPM had HPTuners and did quite a few of their own tunes, but I have no idea what they adjusted on them and frankly I don't care. I was the only tuner in town for a long time who tuned the positive trims out first and then flatlined the PE table where I wanted to command the A/F. This was at a time when all the shops in town were doing exactly what you just accused me of, and thanks to this that's why I tuned hundreds of cars in a short time frame for a lot of really happy folks.
Now if you don't understand the concept of adjusting the PE table to diagnose a fueling problem then I'm not sure you should be diagnosing anyone's car. But now I'm done with this discussion because I learned a long time ago if you argue with an idiot they just pull you down to their level and then beat you with experience
Cheers!
Old May 21, 2013 | 06:47 AM
JMBLOWNWS6's Avatar
JMBLOWNWS6
Cheers!
Consider this I bought the tr224 cam from YOU. I had RPM (CJ) install it and you tuned it. I called you on the way home and told you I had issues and a SES light. Your excuse was I didnt have enough time to get it all squared away. Then when I finally got smart enough to look into it and you did exactly what I stated. On a no cat car you had the rear 02's enabled and couldn't even uncheck a no report. I have been part of cars you can never touch on the street or the track. So stop trying to act perfect when you are far from it. Im not perfect either but you make this sound like we dont know what we are doing and you are sadly mistaken. But thanks for trying.
Old May 21, 2013 | 08:52 AM
Flash20's Avatar
Flash20
Lethal FTW!
Old May 21, 2013 | 09:54 AM
carlos@redline-motorsports's Avatar
0carlos@redline-motorsports
Former Vendor
Yes.
Yes.
The P/E table should be set to what you want to command in terms of actual AFR at wide open throttle. Raising it will richen the car up but it is not the "correct" way of doing it i.e. Raping the P/E table. Similar to Raping the Injector tables which should also be used as constant values.
The correct methods being, as already stated, via the MAF and/or virtual VE tables.
That said, the 60's should be plenty of injector at that power level with regular gasoline and the meth injection should provide even more head room.
Old May 21, 2013 | 10:05 AM
helga203's Avatar
helga203
Originally Posted by carlos@redline-motorsports
Yes.
Yes.
Old May 21, 2013 | 10:08 AM
FloydSummerOf68's Avatar
FloydSummerOf68
When I got my car on another tuners dyno it was hitting 13.5-13.7. Luckily I had suspected the tune was junk and I was there for a re-tune that day. By the end it was making more power much safer.
Good luck getting yours squared away.
Old May 21, 2013 | 10:26 AM
Dragracer_Art's Avatar
Dragracer_Art
If the car is meth injected, I would look into that also.
My tune is a "meth-dependant" tune. Before driving away after getting mine off the dyno, the tuner told me: "Whatever you do... ALWAYS be sure you have meth in that tank"
Old May 21, 2013 | 12:35 PM
LethalTT's Avatar
LethalTT
I think we should be able to get it squared away pretty easily once we get it back up for a tune.
Old May 21, 2013 | 12:45 PM
  #33
Michael ZR1's Avatar
Michael ZR1
I wouldnt like being meth dependant I prefer to use it for extra safety
Old May 21, 2013 | 01:02 PM
  #34
DSteck's Avatar
DSteck
Originally Posted by mikes6c
so.... fix the tune
Pending no underlying fuel supply issue, this is the route to take. Fuel pressure gauges are cheap, and even an electrical one that you can throw in the car is only a couple hundred bucks... It will tell you right away what's going on.
Old May 21, 2013 | 01:56 PM
  #35
LethalTT's Avatar
LethalTT
Car has a fuel pressure gauge, and as stated before I saw no drop in fuel pressure but maybe I missed it when paying attention to AFR.
Old May 21, 2013 | 04:19 PM
  #36
Former Vendor
If it's tuned for meth, it's meth dependent.
Old May 21, 2013 | 05:11 PM
  #37
DSteck's Avatar
DSteck
Not always.
