C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Trans cooler update...
Old Jun 24, 2013 | 03:36 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
Default Trans cooler update...
I am posting this because when I posted about my trans cooler install in another thread there were concerns mentioned about whether or not it would work well being installed in the front fender well. In case anyone is considering a similar install here are my findings after a reasonable time with the setup.
I am using a B&M cooler with a fan on it. The brake duct leads air to the cooler and I installed a grill in the fender well ot evacuate air behind the cooler.
Intially, I used the temp switch supplied by B&M with the cooler and found that by the time it heated up enough to switch on the fans, the actual trans temp was already higher than I liked. I have since wired the fan to run all the time and after today, I am convinced this is a successful install, and would do it again.
It is 90 degrees today and extremely humid.
I drove 2 hours on the highway and the trans temp settle at about 155 and stayed there. In some stop and go traffic it creeped up to 165 but not over that today. I have seen it go to 180 after a prolonged traffic jam but that is the max I have seen and am happy with that result.
Hope this is helpfull to someone....
Old Jun 24, 2013 | 04:37 PM
jon6.0's Avatar
jon6.0
Hmm. I might do that for an oil cooler setup as my base C6 has none right now. Thanks for the pics. What's the part number or size of that cooler? What grill did you use?
Old Jun 24, 2013 | 04:47 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
Its the smaller one. The big one doesn't fit there.
http://bmracing.com/?wpsc_product_ca...cooling-system
I plan to replace the grill with something nicer. All I could find at the time was a heating vent grill from home depot which I painted black.
Old Jun 24, 2013 | 07:52 PM
Le Mans Z06's Avatar
Le Mans Z06
Nice, do you have a stall?
Old Jun 24, 2013 | 09:13 PM
thehulk's Avatar
thehulk
Thats the 200+ degree question.
Old Jun 24, 2013 | 09:24 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
I do. Circle D triple disc 2800.
Old Jun 25, 2013 | 01:43 AM
ironhorse583's Avatar
ironhorse583
nice job.. y did u choose the passenger side over the drivers.? did u have to relocate the horns.?
Old Jun 25, 2013 | 06:31 AM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
Good question and I don't have an answer. I just automatically went for the drivers side as the tranny lines were originally on that side. I ran braided lines from the back and bypassed the rad so I could have done either. I may have been thinking that I might change my mind and run through the rad which would make that side easier. I have since changed to a dewitts with no trans cooler in it. I didn't have to move the horns although they have been previously moved a little during the eforce install and I don't remember exactly where they sat when stock.
Old Jun 25, 2013 | 11:16 AM
Dragracer_Art's Avatar
Dragracer_Art
Judging by the looks of your vent... maybe you can turn the fan on/off with one of these...
Old Jun 25, 2013 | 11:19 AM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
Originally Posted by Dragracer_Art
Since you used a Home Depot vent... maybe you can turn the fan on/off with one of these...
I installed that exact item, but then decided I don't need to turn it off so I removed it. I it really looked sharp mounted on the dash !!
Old Jun 25, 2013 | 01:46 PM
Le Mans Z06
I have the Dewitt's radiator with the TOC and EOC combo, can the external fan be paired with the radiator I have? I had ECS install it so I don't know how the lines and such work. Thanks
Old Jun 25, 2013 | 03:20 PM
ajrothm's Avatar
ajrothm
Good to know!
I just installed mine yesterday. It will be a few more weeks before its running though as I am doing an oil cooler install as well.
I have not "meshed" over the fan yet in the fender well...I am thinking about just leaving it open like above... I rarely drive in the rain but..... not sure if any water at all will kill the fan.
Are you getting your tranny temps from the oem internal tranny temp sensor or an external/aftermarket sender?
Old Jun 25, 2013 | 10:25 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
Originally Posted by ajrothm
Good to know!
Looks good. I get the tranny temps from the DIC and stock internal sender. The reason I put a grill over it was more for debris thrown by the tire than for water.
Old Jun 25, 2013 | 10:27 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
A separate fan would have to go with a separate cooler. The TOC in the dewitts would be cooled by the radiator fan.
Old Jun 25, 2013 | 11:05 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
Very nice work and like those results
Old Jun 25, 2013 | 11:32 PM
londonk's Avatar
londonk
nice work i just did my trans cooler with two small thin coolers from jegs
i did the rad bypass no fan sees about 150 to 160 max
Old Jun 26, 2013 | 08:44 AM
ironhorse583
this is all really good info....did u ever run the cooler in series with the radiator..? i kno there has been alot of discussion about not bypassing the radiator.... can the trans fluid b too cool..? say on a 60 degree night..
To Trans cooler update...
Old Jun 26, 2013 | 09:01 AM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
After reading all I could find on the topic I decided to bypass the rad. Without the fan on the cooler running the trans heats up more than I like so what I did is put a very accessible inline fuse to the fan under the hood. When it gets cooler out, if I find that the temps are staying to low, I will just pull the fuse and run without the fan. Should work out perfectly.
My main concern was in hot weather as this is a summer toy for me.
Old Jun 26, 2013 | 02:29 PM
ironhorse583
the inline fuse is a good idea...last question..where did u find the 12v switched power source..???
Old Jun 26, 2013 | 03:31 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
I all ready had one coming nearby from another installation but until I realized that I was going to take it from the fuse box. Any switched would work as long as you use a relay for the fan. I think I had planned on using the O2 sensors fuse, if I remember right.
