Thanks Josh! I spoke with you a few days ago about heating issues and purchased a Dewitt's rad. I also purchased a Derale -10 oil cooler. I've Been having major, major problems with the shop that's doing the work, so It'll be awhile before I have all of these things installed. After getting off of the phone with you, I went straight to a motorcycle shop and picked up some hi-temp clutch fluid.
The brand new DYAD that was installed is destroyed. I'm pretty sure that it was an issue with the install, but that's another story.
Sorry to hear about all your issues. Good luck with it and finding the best shop for the job.
Looking to goto an external oil cooler behind the fog light, and a rear mounted transmission cooler. I want to have the radiator only cool water, and separate the oil/tranny fluid into separate coolers. Anyone have ideas, part numbers, etc?
Basically want one of these for oil, and then a smaller one in the back for tranny.
