C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
do tires make a diffrence on the dyno
Old Sep 12, 2013 | 05:41 PM
Michael ZR1's Avatar
Michael ZR1
Default do tires make a diffrence on the dyno
Does your rear tire affect dyno numbers
Old Sep 12, 2013 | 05:43 PM
ZO6er's Avatar
ZO6er
yes....
Old Sep 12, 2013 | 05:52 PM
carlrx7's Avatar
carlrx7
St. Jude Donor '08-'09
I have seen bias ply slicks make more on the dyno.
-Carl
Old Sep 12, 2013 | 05:53 PM
Michael ZR1
Ok.... I am going to a dyno shootout should I run my 19" nitto drag radials or 20" Michelin ps2 ?
Old Sep 12, 2013 | 06:08 PM
Unreal's Avatar
Unreal
Whichever is lighter. I've seen heavy wheels take power away.
Old Sep 12, 2013 | 06:28 PM
Michael ZR1
Ill have to weigh them
Old Sep 12, 2013 | 06:30 PM
PowerLabs's Avatar
PowerLabs
From: Greater Detroit Metro MI, when I'm not travelling.
Pump them up more; the stiffer the tire, the less rolling resistance.
Old Sep 12, 2013 | 08:00 PM
newschool's Avatar
newschool
-Carl
Its usually the opposite.
Old Sep 12, 2013 | 08:13 PM
PowerLabs's Avatar
PowerLabs
Indeed. Rolling resistance and rotating mass will impact the dyno reading. Slicks will increase rolling resistance because they are softer. But maybe compared to a run flat they are so much lighter that the net effect is a small gain?
Old Sep 13, 2013 | 05:12 AM
narush's Avatar
narush
I would do the NITTO's
Old Sep 13, 2013 | 06:43 AM
Dragracer_Art's Avatar
Dragracer_Art
If they spin on the rollers they won't do you much good.
I only have Hankooks... so when RPM dyno'd mine, they put VHT on the rollers because the tires 'kept spinning.
Old Sep 13, 2013 | 08:35 AM
Unreal's Avatar
Unreal
I'm going to a dynapak when I tune. That way no wheel spin and no issues with rear wheels.
Old Sep 13, 2013 | 08:44 AM
turbotuner20v's Avatar
turbotuner20v
I'd go with the 20's at a few psi over the recommended inflation.
Old Sep 13, 2013 | 08:47 AM
Pb82 Ronin's Avatar
Pb82 Ronin
In my experiences on the dyno...softer sidewall tires such as D/R's and slicks result in less power. This is not true in EVERY case however. The most extreme I've seen was a blown Cobra with 325/50/15 ET D/R's. No mods or tuning done, just brought it back a week later with his "street wheels" on and picked up 46 rwhp. Factoring in weather variations and dyno error...I'd say a safe bet was at least 90% of that gain was tire related.
A general statement I'll make is that usually...softer sidewalls result in less transfer of energy into the rollers...thus a lower output.
realcanuk's Avatar
realcanuk
St. Jude Donor '13
Why worry about tires ....
Old Sep 13, 2013 | 12:06 PM
Drewstein's Avatar
Drewstein
I'd go with the 19s. I bet the 20s are heavier and will dyno lower.
Old Sep 13, 2013 | 02:47 PM
East Tx Muscle Cars's Avatar
0East Tx Muscle Cars
Former Vendor
the lighter the wheel
the shorter tire
the harder tire
will get you the most
To do tires make a diffrence on the dyno
Old Sep 14, 2013 | 01:14 AM
J Christensen's Avatar
J Christensen
A few years back I went to Daytona Bike week with my ZX-14, with about 1k miles on it. I met up with a friend who has been a professional mechanic for a top racer.
He did the dyno drag, using my bike and his 11 year old son. He let a lot of air out of the rear tire, set the roller so the tic mark would trip right after the throttle was hit, and the bike got the best 1/4 dyno drag for Daytona that year.
Near the end of the bike week a new Hayabusa wanted to go up against my bike. My friend used his son again and the same
tricks'. My bike got an 8.6, 8.5 and 8.5 quarter mile. The Hayabusa a 10+, and two in the mid 9's.
I told the girlfriend of the Hayabusa owner her sweetie had been setup.
Old Sep 14, 2013 | 03:59 AM
nareg's Avatar
nareg
it might make a difference, but regardless id suggest getting the car tuned or make passes on the dyno with the tires you'd want to use on the road or track.
Old Sep 14, 2013 | 08:56 AM
Unreal's Avatar
Unreal
Depends on the dyno too. Like I said above, on a dynapak you remove the rear wheel so there is 100% no way they will have any effect.
