C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
is something wrong?
Old Oct 15, 2013 | 03:23 PM
jonathontodd's Avatar
jonathontodd
Originally Posted by Frans96ss
Where are you located?
Virginia
Old Oct 15, 2013 | 03:35 PM
Jeffro_510's Avatar
Jeffro_510
What spark plugs are you running?
Old Oct 15, 2013 | 03:49 PM
jonathontodd
Zr1 Plugs Ac DelCo 41-110
Old Oct 15, 2013 | 05:11 PM
saplumr's Avatar
saplumr
The guy above from Delaware is pretty good. Time for a road trip and someone who actually knows something.
Old Oct 16, 2013 | 10:08 AM
robertaj's Avatar
robertaj
just a thought but even if he will "make it right" i would be scared.... eat the coupl ehundred on the tune and take it to somewhere that won't have your engine blow up because they didnt quite get the tune right.... or were guessing about a few things....seems crazy to gamble with your engine to save a few bucks.
Old Oct 16, 2013 | 05:50 PM
jonathontodd
I Stopped By The Shop, I'm Around $700 IntO This Tune Already. Needless To Say, I'm Not Happy. Ricefed, Do You Have Your DYno Sheet? I Would Like To Compare If You Don't Mind.
Old Oct 16, 2013 | 10:30 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
At some point it is better to cut the losses and move on. A tuner that doesn't know his stuff is dangerous. I would find someone who does.
Old Oct 17, 2013 | 08:06 AM
Dragracer_Art's Avatar
Dragracer_Art
Ditto this.
How much would it cost to replace or repair the engine when the hotshot tuner blows it up ? $700 is small potatoes in comparison.
Old Oct 17, 2013 | 09:56 AM
jonathontodd
Not Sure What Can Be Determined From Looking At The Dyno Printout. BUt There It Is.
Old Oct 17, 2013 | 10:47 AM
Frans96ss's Avatar
Frans96ss
St. Jude Donor '09
Originally Posted by jonathontodd
Virginia
Not a plug i would run. If you want to have me look over the car and retune it give me a call. I can get you taken care of.
Old Oct 18, 2013 | 07:55 AM
ALTECH's Avatar
ALTECH
St. Jude Donor '14
It sounds like weak valve springs or plugged cats. Be careful his could kill an engine. Good luck.
Old Oct 18, 2013 | 10:53 AM
Chance575's Avatar
Chance575
NGK TR-6, plugs you should run
Old Oct 18, 2013 | 11:50 AM
  #33
Detoxx03's Avatar
Detoxx03
Running the wrong plugs for one and two just let Fran get you right. Better to spend money on some gas and tune than a motor build.
Old Oct 18, 2013 | 04:40 PM
  #34
jonathontodd
Thanks To Everyone For The Info. Going To Take It Somewhere Else, Delaware Is Kind Of Far, But Thinking About It.
Going To Swap To An Ls3 Maf, Change The Spark Plugs And Get It TUned
Old Oct 22, 2013 | 09:16 AM
  #35
Dragracer_Art
The drive to Delaware is worth it in my opinion.
See my sig...
BTW... I run the colder #7 plugs in my car and don't have any issues. They are safer than the #6 plugs.
The LS3 MAF requires a harness adapter and different tune... so you may want to prep all the parts for installation and drive to the shop on the LS2 MAF. Only takes a few minutes to swap the LS3 MAF when you get there.
I swapped in a whole set of injectors in Fran's parking lot when I went for my tune.
Old Oct 22, 2013 | 09:21 AM
  #36
realcanuk's Avatar
realcanuk
St. Jude Donor '13
Smart move taking it to someone who knows what they are doing. Unless the maf is defective, it is not your problem. I run on the stock LS2 maf, and a maf only tune, without issue.
I was running 600rwhp with the stock maf frequency, which I later extended with a simple upgrade to HPT 2 bar OS. If you max the 12200 stock limit (which I doubt at your power) a simple OS upgrade will extend it. No need to change the actual MAF>
