C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
is something wrong?
Old Oct 13, 2013 | 01:04 PM
jonathontodd's Avatar
jonathontodd
Default is something wrong?
Procharged 2007 Ls2
Z06 Exhaust ( Manifold To Tips)
4.25 Pulley, Boost Gauge Reads 7.5Psi
Peak Hp, 478
Falls On Its Face At 5800Rpm.
Tuner Thinks The Stock Ls2 Maf Is Maxed Out.
Was Expecting Around 525rwhp
Old Oct 13, 2013 | 01:07 PM
jonathontodd
Car Is A m6
Old Oct 13, 2013 | 01:34 PM
ricefed's Avatar
ricefed
MI Events Coordinator
Something has to be wrong. My car an 07 when I was completely stock besides a A &A kit made 546 at 7psi on a dynojet.
Old Oct 13, 2013 | 02:39 PM
1320IN9's Avatar
1320IN9
maybe some valve float. stock springs or upgraded?
Old Oct 13, 2013 | 02:41 PM
jonathontodd
Ricefed, Did Your Tuner Change Anything With You'R Maf Tables? Motor Is Completely Stock.
Old Oct 14, 2013 | 02:22 PM
jon6.0's Avatar
jon6.0
As was asked already, stock valve springs? How many miles on the motor?
Old Oct 14, 2013 | 04:36 PM
jonathontodd
Motor is completely stock. 49k miles. Going to swap to an ls3 maf, see if that changes anything
Read in a few place the stock ls2 maf maxes out around 450rwhp.
Old Oct 14, 2013 | 04:50 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
There is no way your MAF is maxed out. Your tuner should know that by logging what the car is doing.
Old Oct 14, 2013 | 06:16 PM
saplumr's Avatar
saplumr
You're down somewhere in the neighborhood of 60hp. I'd be looking for a boost leak.
Old Oct 14, 2013 | 08:47 PM
jon6.0's Avatar
jon6.0
Tuner problems perhaps?
Old Oct 14, 2013 | 09:09 PM
Jeffro_510's Avatar
Jeffro_510
Agreed
Old Oct 14, 2013 | 09:45 PM
playtoy's Avatar
playtoy
What procharger is it? My stock ls2 with cam, meth and headers made 700 with a 4.25" pulley on a d1sc. It's an m6 so I would expect it to be higher any way, but it made 535 with just headers and a 4.5" pulley.
Old Oct 15, 2013 | 05:16 AM
ricefed's Avatar
ricefed
I couldn't tell ya lol. I just know I was hoping for 525 and he exceeded that. Not sure what his screen name is on this forum but everyone calls him Dr. Phil.
Old Oct 15, 2013 | 06:54 AM
Dragracer_Art's Avatar
Dragracer_Art
Unless the MAF is bad... it should work fine at that power level.
I'm still running my stock 2005 LS2 MAF at 636rwhp.
Old Oct 15, 2013 | 11:44 AM
Frans96ss's Avatar
Frans96ss
St. Jude Donor '09
If your tuner "thinks" the maf is maxed out. Please take it to a diff tuner.
Old Oct 15, 2013 | 11:53 AM
jonathontodd
SpoKe With Another Local Tuner, (Thinks I Should Be Closer To 550Rwhp), Not Sure If THe Guy Who Tuned It Is Familiar With How To Scale The MAF Tables.
Since I Already Have The Ls3 Intake Tube, I'm Going To Use ThE Ls3 Maf Sensor. (What's Another $75),
I Will Probaby End Up Taking It Somewhere Else. But Going To See If He WilL Make It Right First.
Old Oct 15, 2013 | 11:54 AM
jonathontodd
Only Question I Have, Will The Stock Maf Work Without Scaling It Back. (Ls2)?
To is something wrong?
Old Oct 15, 2013 | 12:44 PM
Frans96ss's Avatar
Frans96ss
St. Jude Donor '09
Where are you located?
Old Oct 15, 2013 | 12:52 PM
ajrothm's Avatar
ajrothm
Definitely low on power. You should be seeing way more then 7.5 psi with a 4.25" pulley on a D1sc, especially with stock manifolds. Must have a pretty good boost leak somewhere for starters... Or the belt is slipping.
My stock LS6 with a 4.38" pulley would make 10-11 psi with headers.. 622hp...
I would pressure up your system and go over everything with soapy water and check for leaks... Check for belt slip.. Then go from there.
With a 4.25 pulley I would expect you to see 11-12 psi, especially on stock manifolds. Unless you're at high altitude or something.
Old Oct 15, 2013 | 02:32 PM
jonathontodd
IT Is A P1sc, I SpokE To The Tuner, He Said I Maxed Out The Frequency Of The Maf.
And Scaling ThE Maf Tables Won't Help Because Its Out Of Frequency.
