C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
boost
Old Oct 13, 2013 | 08:30 PM
redline06's Avatar
redline06
Default boost
hey guys have been running my edelbrock 1593 eforce for a week now and want to know what type of boost I will see with headers and hi flow cats and corsas. blower pulley is stock along with the canned edelbrock tune. the car is an06 ls2 with an A6.
Old Oct 14, 2013 | 09:39 AM
jxhunte's Avatar
jxhunte
I can't tell you what boost you will see but I can give you info from my data logs of 1/4 mile passes at Bandimere Speedway with the 3.875", 3.5", and 3.25" pulleys (06/C6/LS2/1.8 quick lift roller rockers/Kooks Long Tubes).
Readings taken at approx. 6K RPM:
3.875" pulley - 6lbs
3.5" pulley - 8lbs
3.25" pulley - 10lbs
Old Oct 14, 2013 | 08:01 PM
redline06's Avatar
redline06
jx so if you where running at bandimere outside Denver and got 6lbs of boost with the 3.8 than at sealevel I should see around 8lbs
Old Oct 15, 2013 | 09:28 PM
jxhunte's Avatar
jxhunte
Edelbrock advertises 6lbs of boost for the base 3.8" pulley. Not sure what you will see. I can only tell you what I have experienced. I manually calculate boost based on MAP readings taken from data logs. Example: Map reading of 144Kpa @ 6,200 RPM, converting Kpa to lbs (144 X .1450377377) = 20.885lbs minus the density altitude or in my case 9,000 feet (air pressure for 9K feet is 10.5lbs) which equals 10.385lbs of boost.
Old Oct 15, 2013 | 09:39 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
I get about 12lbs with a 3 inch pulley. I really cant remember what I got with the others, but about 2 lbs per pulley size seems to be about right.
Old Oct 18, 2013 | 05:21 PM
Thomasmoto's Avatar
Thomasmoto
Ours puts out 5.5 lbs with headers and hi flo cats. 2011 LS3 3.75" pulley #1591 599hp kit. I thought it would be around 7lbs, but 5.5 is all we're getting. I want to go to the 3.50 pulley, but they are saying it would need bigger injectors as well as a new tune. I didn't think a pound and a half of boost would make that much difference, but they say yes.
To boost
