C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
E-Force Prep
Old Dec 22, 2013 | 10:14 AM
da_vato's Avatar
da_vato
Default E-Force Prep
Well I have been on the forums for a while and was trying to stay away from the FI portion because of a previous vehicle that I added a supercharger to (good and bad experiences). Somehow I talked myself back into going down the FI route with an E-Force SC.
My car is stock right now with the exception of the Vararam CAI. I am pretty sure I have to get another shroud since I had to cut mine to install the intake. Is this true and is there anything else I should do to prep the car for installation of the E-Force?
Old Dec 22, 2013 | 01:09 PM
Cordes Performance Racing's Avatar
Supporting Vendor
Are you a manual or automatic car? If manual plan on buying the updated alternator with the clutch style pulley of you don't have it already. Extremely common for the pd blower cars to spin the nut off the alternator pulley if you hit the Rev limiter.
__________________
Cordes Performance Racing aka "CPR"
Owner of AZ's premier LSX/LTX motorsports shop
http://cordesperformanceracing.com/
www.facebook.com/cordesperformanceracing.com
joe@cordesperformanceracing.com
480-359-5914
Old Dec 22, 2013 | 01:22 PM
da_vato's Avatar
da_vato
12 Grandsport M6,
I wouldn't of even thought about that, thanks.
Old Dec 22, 2013 | 03:56 PM
Supporting Vendor
It's well worth it, very common issue and I wish Edelbrock would state it in the install instructions. Some people get away with taking the nut off and using red loctite.
Old Dec 22, 2013 | 04:11 PM
jon6.0's Avatar
jon6.0
When did cars start getting the updated alternator Joe?
1BADLS's Avatar
1BADLS
Just a warning, don't ever go smaller than a 3.25" pulley. I had an Eforce installed on my 08 LS3 Coupe in March 2013. My motor blew last Sunday. I'm not sure if too much boost was the problem, but I had a 3" pulley on my car and about 11lbs of boost. Needless to say, the entire motor and Eforce are now a pile of aluminum scrap.
Old Dec 22, 2013 | 04:14 PM
jon6.0's Avatar
jon6.0
I would want to look at your tune. Lots of folks run 10-15psi on stock LS3's with no issues.
Old Dec 22, 2013 | 04:55 PM
Unreal's Avatar
Unreal
Only really an issue with the PD blowers. For some reason they like to put some wierd back torque on the belt, probably because the rotors don't slow down quick enough when letting off at high speed.
Old Dec 22, 2013 | 05:14 PM
1BADLS's Avatar
1BADLS
Actually, a connecting rod broke under the piston in the #1 cylinder.
Old Dec 22, 2013 | 07:30 PM
Supporting Vendor
That I don't know, however as of late all replacement gm alternators have been coming with the clutch style pulley. We had a 07 manual c6 come in that I gave the last 8 of the vin to them and the clutch style came. I called and they told me it superceded the old one. Have not had another car as of late need a new alternator to do this again and verify.
Old Dec 22, 2013 | 07:40 PM
Red Sleeper's Avatar
Red Sleeper
I just took a look at my alternator. Can't see the nut. Does that black plastic piece just pop out?
Old Dec 22, 2013 | 08:16 PM
Supporting Vendor
You have the clutch style if you have a black cap over where the inside of the pulley would be for a nut to take it off.
Old Dec 22, 2013 | 08:25 PM
arp35's Avatar
arp35
You will need a new radiator shroud. Take a look at my thread I started about a month ago. Also, look at the instructions for the install and it will list some items needed. Decide on which method you want to use to pin the crank. And also think about how you will remove the harmonic balancers bolt. Otherwise, it is pretty straight forward, just plan on a few days. Also, it is heavy so you will need another person to help you lift it on the engine.
Old Dec 25, 2013 | 01:14 PM
da_vato's Avatar
da_vato
Thanks for the good info guys.
To E-Force Prep
