C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Forced induction and headers
Old Jan 6, 2014 | 02:24 PM
THE BLADE's Avatar
THE BLADE
Default Forced induction and headers
Is it true that headers aren't worth much when using forced induction?
Old Jan 6, 2014 | 02:29 PM
jon6.0's Avatar
jon6.0
Whoever told you that should be smacked on the back of the head.
Old Jan 6, 2014 | 02:30 PM
jon6.0's Avatar
jon6.0
You obviously wouldn't use them for a turbo build, but they make a big difference on blower builds.
Old Jan 6, 2014 | 02:48 PM
Unreal's Avatar
Unreal
Depends on what you mean by much. If you are hoping for 200rwhp, then no, they don't add that. Then again they don't add that on n/a builds. Headers are pretty much a must have on a blower car. You are forcing air in, you need to get it out. I've seen 50+ gains with adding headers on a mild blower setup. Heck, I'm hoping for 20-35rwhp gains just going from one header to a different one.
Old Jan 6, 2014 | 05:10 PM
THE BLADE's Avatar
THE BLADE
I am still doing research on my GS build and placed a call to Lingenfelter today, and was told on a blower install headers don't make much difference and are not needed. We talked about their 670hp kit.
Old Jan 6, 2014 | 05:17 PM
jon6.0's Avatar
jon6.0
Since they rate their stuff at the flywheel and not wheel HP, then I would guess that package is somewhere in the 550rwhp range. While not necessary for that level, they definitely would add power above what they rate that package for. I also wouldn't have them do my car since I'm a cheap bastard and I like centri blowers better.
Old Jan 6, 2014 | 05:23 PM
ZO6er's Avatar
ZO6er
It's all a myth
Old Jan 6, 2014 | 07:02 PM
Turbo-Geist's Avatar
Turbo-Geist
2017 C5 of Year Finalist
Originally Posted by ZO6er
It's all a myth
B,Bu, But...
Old Jan 6, 2014 | 09:13 PM
Streetk14's Avatar
Streetk14
I wish I had thrown my car on the dyno with the full LS9/ZR1 exhaust setup last year before I pulled them off for a set of Pfadt headers. I'm sure there was a 30 rwhp difference, but at ~700 whp, it's kind of hard to tell from the SOP difference.
I will say that the manifold setup was less tolerant of timing and showed more knock retard during tuning. I wasn't able to run the kind of timing I could with headers. I'd suspect a stock LS3 manifold setup would be quite a bit worse, too.
Old Jan 7, 2014 | 01:22 AM
lt1z's Avatar
lt1z
Originally Posted by Streetk14
I wish I had thrown my car on the dyno with the full LS9/ZR1 exhaust setup last year before I pulled them off for a set of Pfadt headers. I'm sure there was a 30 rwhp difference, but at ~700 whp, it's kind of hard to tell from the SOP difference. I will say that the manifold setup was less tolerant of timing and showed more knock retard during tuning. I wasn't able to run the kind of timing I could with headers. I'd suspect a stock LS3 manifold setup would be quite a bit worse, too.
The LS7/9 manifolds are far better then LS3 manifolds but were still down 25 or so to headers on my car when it was in the low 600 range.
To Forced induction and headers
