C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Belt Length?
Old Mar 12, 2014 | 07:48 AM
MARSC6's Avatar
MARSC6
Default Belt Length?
For some reason I found a couple different lengths when searching the part number. Its a Gates 25-060900 from an ECS kit.
Old Mar 12, 2014 | 03:03 PM
zuluvett's Avatar
zuluvett
3.25" pulley i run the Gates K060888
Old Mar 12, 2014 | 03:26 PM
MARSC6's Avatar
MARSC6
I was considering trying out a Gatorback belt but wanted to make sure I know the correct length. Maybe I should just stick with what I've been using.
Old Mar 12, 2014 | 03:28 PM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
We use the k060888, but we send them out with a k060891 because we have had complaints that not only DIY'rs, but shops cant get them on. I don't personally understand this phenomenon, but if it was my own car I would use the 888.
Old Mar 12, 2014 | 03:31 PM
grady's Avatar
grady
Doug;
What would you recommend on a 3" pulley on an enforce? I have the 599 kit with the 3.5" pulley but I purchased a 3" from you folks and was going to install next week.
Thanks much
Old Mar 12, 2014 | 03:33 PM
DOUG @ ECS's Avatar
DOUG @ ECS
Originally Posted by grady
Doug;
Thanks much
Sorry I'm not as up to speed with Eforce belts, I would refer directly to them on that one. My guess would be the next size down from what comes with the kit though.
Old Mar 12, 2014 | 03:44 PM
MARSC6's Avatar
MARSC6
So I must be way to long with 060900.
Fighting with the belt will give me something to do while waiting on the intercooler.
Old Mar 12, 2014 | 03:48 PM
MARSC6's Avatar
MARSC6
I also still have the old style tensioner if that means anything.
Old Mar 12, 2014 | 05:08 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
Doug;
Thanks much
The same belt will work fine with that pulley.
Old Mar 12, 2014 | 05:46 PM
DOUG @ ECS's Avatar
DOUG @ ECS
Wont make a difference, but check to see if you have a 3.25" pulley or 3.5". The 3.5 will work with the 900.
Old Mar 12, 2014 | 06:07 PM
MARSC6's Avatar
MARSC6
Its the 3.25
I was hoping I needed the smaller pulley
To Belt Length?
