C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Whipple??
Old Mar 24, 2014 | 03:56 PM
Unreal's Avatar
Unreal
Tell me about it. My car has been apart for about ~5 weeks and it is killing me. Should have it running this week. Just need to put the passenger side header on.
Back to the OP, if you want 800rwhp daily/etc I would just do a Ti or Ysi. You could even pulley it for max boost and just do a restrictor plate and make more low end than you could hook on any decent tire. If you want 725rwhp or less then do the whipple.
Old Mar 24, 2014 | 04:01 PM
ace32x's Avatar
ace32x
Has any one tried fitting the kennebell units on these like d3 does on the lsa platform
Old Mar 24, 2014 | 04:07 PM
ZO6er's Avatar
ZO6er
Folks with whipples, are you running on Ethanol?
Old Mar 26, 2014 | 04:31 PM
izaks's Avatar
izaks
Cruising
I am running a 2.9 FF Whipple on a 416 LS3 at 16psi, making more than 800rwhp.
On a recent 9 sec run on a load (mustang) dyno the IAT went from 95F at the start of the run, to 170F at the end of the run.
Old Mar 26, 2014 | 08:44 PM
harveyjl's Avatar
harveyjl
Originally Posted by Unreal
Tell me about it. My car has been apart for about ~5 weeks and it is killing me. Should have it running this week. Just need to put the passenger side header on. Back to the OP, if you want 800rwhp daily/etc I would just do a Ti or Ysi. You could even pulley it for max boost and just do a restrictor plate and make more low end than you could hook on any decent tire. If you want 725rwhp or less then do the whipple.
Thanks unreal. I wish whipple would do a 3.3 for the Vette.
Old Mar 26, 2014 | 09:51 PM
ZBADESTZ@Straightline's Avatar
Originally Posted by ace32x
might not be as bad as you think as long as the heat exchanger is decent, on back to back runs on my tvs 2300 we were staying right around 100-110. thats just an upgraded heat ex on stock intercoolers and stock coolant reserviour
Ace you will get your real numbers on the street....Have him do some 2-3-4 hard pulls then see where your temps are.....
Still want to see a log with spray....
Old Mar 26, 2014 | 10:41 PM
ace32x's Avatar
ace32x
he did a few back to back 3rd gear runs later that day after tuning and said they were right around 110
