C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Another tune question.
Old Mar 28, 2014 | 09:02 AM
chevnut55's Avatar
chevnut55
Default Another tune question.
Bring my G/S to be tuned for the A&A install.
Does the tuner check to see if things like the BAP is working and check/adjust the BOV?
Also When I install headers or meth kit will I need to have it tuned again?
Wish I could do the headers now but cant afford it.
Old Mar 28, 2014 | 09:27 AM
Ls240sx's Avatar
Ls240sx
My guess is that the tuner will not check to see if the BAP is working unless there is an issue with fueling. Same goes for the BOV. Most tuners want to show up, do their job and leave.
You will deffinately want to re-tune after you get meth installed to take advantage of the system.
Old Mar 28, 2014 | 09:29 AM
1MEANGS's Avatar
1MEANGS
If you do headers or meth you'll need a retune... I got tuned for just the blower then down the road added the headers myself then dropped off shortly after for a retune and meth install... I was in the same boat, no need to do it all @ once, do it lil my lil you'll enjoy it more that way... Better to mod in stages, it's more cost efficient to do it @ once but gotta have the cash to do so and I think it boring because you have nothing to look forward too... Tuner will know if BAP is working because if not you'll be maxing out on fuel and not have sufficient fuel pressure if it isn't working properly... As for the BOV I don't think they usually check stuff like that unless it's not working right and not closing under boost or opening on blow off! Good luck w/ everything! Love boosted Grandsports (:
To Another tune question.
