C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
PCV system?
Old Mar 29, 2014 | 11:19 PM
Realfast86's Avatar
Realfast86
Default PCV system?
How are most guys running the PCV system on cars with twins wondering how i should do it on my LSX build probably run a single plane or sheet metal intake with a flat valley cover.
Old Apr 1, 2014 | 11:53 PM
Realfast86's Avatar
Realfast86
Bump!
Old Apr 2, 2014 | 12:01 AM
edge04's Avatar
edge04
You'll get varying answers but here is what I do
-12 or -10 off each valve cover to a good baffled catch can.
Old Apr 2, 2014 | 08:13 AM
Realfast86's Avatar
Realfast86
No need to pull the air through the can with a line pre-turbo?
Old Apr 2, 2014 | 10:12 AM
Ls240sx's Avatar
Ls240sx
mine go -10 from each cover and -6 from crankcase to catch ca. Catch can has 2 -10 hoses to each intake
Old Apr 2, 2014 | 10:17 AM
yur2slo's Avatar
yur2slo
Originally Posted by Ls240sx
Do you just cap off the valley cover port when doing that setup? I just had -10's put on my valve covers and looking to do the same.
Old Apr 2, 2014 | 10:19 AM
Ls240sx's Avatar
Ls240sx
No, I ran a -6 from the can to the valley cover port
Old Apr 2, 2014 | 10:23 AM
Realfast86's Avatar
Realfast86
So how many lines do you have In-out of the can 5? 3 in 2 out and what can are you using does it have a check valve/s?
Old Apr 2, 2014 | 10:25 AM
Ls240sx's Avatar
Ls240sx
5 lines in total. 3 in 2 out. I made the catch can. It does not have a check valve because it goes to the intake pipes of the turbos so there will always be vacuum.
Old Apr 2, 2014 | 11:10 AM
MIGHTYM0USE's Avatar
MIGHTYM0USE
an open catch can is not a pcv system.
if you want a pcv system it will need to work like stock and use intake manifold vacuum for fresh air exhange into the crank case
here is what i did, my pcv can is sealed under vacuum and vents freely with crankcase pressure.
the only change for twin turbo is the fresh air inlet would just need to go to one turbo, but could be split to both.
i decided to use a single -10 inlet from valve cover vs. the stock hoses. (changed from -6 to 10 on the can after photo), and mounting for c6z application
Old Apr 2, 2014 | 10:14 PM
Realfast86's Avatar
Realfast86
So what is the better system on a street driven car that i dont want to smell or see oil? Is the pvc system needed if you pull from the valley/valve covers by using the turbo inlets and is it possible to pull to much from the crankcase that way?
Old Apr 4, 2014 | 01:22 PM
MIGHTYM0USE
pcv system is what the factory wants, its what the law wants, and a closed system would be the only way to not smell or see oil.
improving on their design with a nice catch can in there, and further one that can withstand high hp and associated blowby is icing on the cake!
you wont pull too hard on the crank case by simply using the turbo air filter suction (well not unless you have a clogged or terribly undersized air filter) but it would be a good place for a catch can as well.
Old Apr 4, 2014 | 01:47 PM
Realfast86's Avatar
Realfast86
So if I were to pull from the valve covers would I need to pull from the valley also? And would any sort of check valves be needed?
To PCV system?
