C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Head gaskets?
Old Apr 16, 2014 | 12:21 AM
Realfast86's Avatar
Realfast86
Default Head gaskets?
Whats the best head gaskets to use on a LSX block with 4.125" bore Cometics,Felpro,GMPP? and what bore size?
Old Apr 16, 2014 | 09:05 PM
Realfast86's Avatar
Realfast86
Crickets!!!!!!
Old Apr 16, 2014 | 09:10 PM
lane_change's Avatar
lane_change
I went with a Cometic 4.205 bore .045 thick head gasket for my 4.165 bore RHS block. Most of the time I prefer to stick with GMPP when possible, but I couldn't find one for my bore size. I know Cometic had some issues in the past, but I've been told that they are working well now, so I'm optimistic.
Old Apr 16, 2014 | 10:10 PM
Unreal's Avatar
Unreal
I'm running the GMPP ones.
Old Apr 16, 2014 | 11:21 PM
Realfast86's Avatar
Realfast86
GM next size is 4.200 and Cometic is 4.185" is that to big for a 4.125" bore i thought the basic rule was around .030 bigger and what would the larger gaskets due to the comp.?
Old Apr 17, 2014 | 01:11 AM
EX1's Avatar
EX1
Never had an issue with GMPP or Cometic
Old Apr 17, 2014 | 03:21 AM
Tuomas FIN's Avatar
Tuomas FIN
Plus 1
Old Apr 17, 2014 | 08:08 AM
Realfast86's Avatar
Realfast86
So what size gaskets are you guys running and what is your bore sizes?
Old Apr 17, 2014 | 08:58 AM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
Bore 4.005
LS9 gaskets. 4.10
Old Apr 17, 2014 | 09:02 AM
Unreal's Avatar
Unreal
4.125 and 4.2 I believe. Whatever is the next size up from 4.125 in the GMPP gasket.
Old Apr 17, 2014 | 09:45 AM
ProEFI's Avatar
ProEFI
Supremacy 1 car at a time
Cometic FTW
Old Apr 17, 2014 | 11:25 AM
lt1z's Avatar
lt1z
GM 4.200 Gaskets
19170419
Old Apr 18, 2014 | 12:00 AM
Realfast86's Avatar
Realfast86
Talked with Cometic today they said they will make any size gasket i want same cost as shelf gaskets just takes a few days so the question is what size should i get 4.155" and also i was planning on .051 thick should i do .040 that would take my comp. up to around 9.6* VS 9.4* will that matter much with twins?
Old Apr 18, 2014 | 12:28 AM
Unreal's Avatar
Unreal
Either one is low. I would go for 10:1.
Old Apr 18, 2014 | 12:30 AM
Realfast86's Avatar
Realfast86
It will be mostly on pump 93 no corn around me!
Old Apr 18, 2014 | 09:32 AM
Unreal's Avatar
Unreal
Would still up it. Best setup I've seen recently was a 416 10.5:1 twin 56mm car. Made 920rwhp/940tq on 10psi pump gas and turbos spooled at ~2k and had a sick power band.
Old Apr 18, 2014 | 10:22 AM
Chance42's Avatar
Chance42
If that's the 5th gen I think you're talking about he had meth injection as well. I think he is also about to rebuild the motor again unfortunately.
Old Apr 18, 2014 | 11:42 AM
Unreal's Avatar
Unreal
Nope and nope.
Old Apr 18, 2014 | 07:50 PM
Realfast86's Avatar
Realfast86
I got the details from the builder today and used the chart to figure out the Comp ratio 4.155 gaskets 0.040 are 9.85-1 and .051's are 9.64-1 builder said no worries on PTV clearance with the cam i'm using!
To Head gaskets?
