C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
E Force SC **** New Upgrades****
Old May 14, 2014 | 11:16 AM
NASTY VETTE's Avatar
NASTY VETTE
Default E Force SC **** New Upgrades****
Ok to give you a little back ground. I purchased my 09 ls3 auto z51 package bone stock early March and decided I wanted to add some hp. I wanted something reliable and nothing to wild, so I went with a Edelbrock E Force 1590 kit. When the kit was installed I had them use the 3.5" pulley and added Lg cat less headers 1 7/8, the car made 510 rwhp and 518 tq at 6-7lbs of boost on 93 pump gas. I was happy at the time and saw that many ls3's with the same set up were around 475-520rwhp. That all quickly came to an end about a week later and decided I wanted a little more getty up lol. So I started doing some research and decided on the following mods….
3" SC Pulley #15822
90mm ATI Idler Pulley #916208-76
Edelbrock upgraded belt tensioner #15034
Gatorback belt #4061030
MSD Programmable Fuel Pump Voltage Booster #2351
FIC 1000CC Injectors
E85 FUEL
HP Tuners Tune by DSMLIGHTS Forum member.
Car made 600 rwhp & 589 tq @ 10-11lbs of boost with only two degrees of timing. I need to buy a smaller belt due to the belt slipping a little but other then that I am the happiest guy around town.
Old May 14, 2014 | 11:35 AM
old motorhead's Avatar
old motorhead
2 degrees of timing?
Old May 14, 2014 | 11:37 AM
NASTY VETTE
Yeah when running E85 it allows for the tuner to add more timing. He told me he could have added another 2-5 degrees of timing and made more power, but I was happy with those numbers and more importantly how the car was behaving.
Old May 14, 2014 | 12:06 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
Sounds great. Should be a blast to drive. Something not right with that timing number though. Never seen a car run good on 2 degrees.
Old May 14, 2014 | 12:07 PM
mobius's Avatar
mobius
hmmm I think you maybe mistaken on the amount of timing you are running. Doubt you made that kinda power on 10psi and 2 degrees. plus E85 likes a lot of timing
Old May 14, 2014 | 12:10 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
3" SC Pulley #15822
E85 FUEL
And by the way. The 90mm idler helps prevent belt slip, but belt size is key. Get a few different sizes to try (return the ones you don't use) and put the shortest one you can get on.
Old May 14, 2014 | 12:13 PM
NASTY VETTE
Awesome, thanks again for all your help!
Old May 14, 2014 | 12:17 PM
NASTY VETTE
Yeah we were surprised on how much power it was making and i didn't really want to push it much more. Just by getting the air fuel ratio good it brought the hp up a lot so he added 2 degrees and it hit 600rwhp i told him i was happy with that. Maybe once i get the smaller belt Ill have him add some more timing to see what it makes.
Old May 14, 2014 | 12:45 PM
NASTY VETTE
Yeah i had the car tuned before and it had timing take already he said he added a few on top of that.
Old May 14, 2014 | 02:04 PM
old motorhead
I think you may have "adding two degrees" and "two degrees of total timing" confused. With E85 being a higher octane fuel, adding 2 degrees is totally understandable. Having only 2 degrees of advance total isn't.
Old May 14, 2014 | 03:56 PM
NASTY VETTE
Yeah its definitely not a total of 2 degrees. He added 2 to what was already on the tune.
Old May 14, 2014 | 06:51 PM
vforrest's Avatar
vforrest
My new E-force 554 has 15 degree's of timing in it on 93 octane with 11.7% air to fuel mix making 42 more HP than the handheld flash that comes with the kit.
Old May 14, 2014 | 07:36 PM
NASTY VETTE
Nice yeah i never used the handheld they are generic.
Old May 14, 2014 | 08:18 PM
grady's Avatar
grady
I'm at roughly those numbers of 591/584 but at 12* timing on 93 octane with pfadt 1.75" headers and the 3" pulley
Old May 14, 2014 | 09:45 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
Nice improvement and you got a really nice setup
Old May 14, 2014 | 10:03 PM
NASTY VETTE
Very nice!!!
Old May 14, 2014 | 10:04 PM
NASTY VETTE
Thank you, I'm happy with the gain. Now I just need some tires lol
To E Force SC **** New Upgrades****
Old May 16, 2014 | 02:29 AM
WHITE_SHARK's Avatar
WHITE_SHARK
great setup, similar to my friend's built 402ci ls2 c6. When he started seeking more power by adding camshaft & AFR heads and 2.85" pulley,,, belt slip faced and Edelbrock recommended an upgraded idler pulley to take care of belt slipping issue.. we will see the result later.
Old May 16, 2014 | 06:30 AM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
Like to know the results also as that's very similar to my set up. If you remember when it's done, please let us know.
Old May 16, 2014 | 09:44 AM
TLS_Addict's Avatar
TLS_Addict
Just got my car back last night.
E-Force 599 kit and added 3.25" pulley, LG 1-7/8" headers, high flow cats, 3" X-pipe, B&B PRT mufflers. End result is 580 rwhp at 5,850 rpm and 611 rwtq at 4,100 rpm.
