C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Rps bc2 question
Old Jun 3, 2014 | 05:39 AM
07blkvette's Avatar
07blkvette
Default Rps bc2 question
I have and rps bc2 insatlled on my car with a tick clutch master cylinder. The clutch is so hard I hate it. I was told to take the tick MC out because thats whats causing the hard pedal feel. Can anyone using this clutch me how this clutch feels compared to stock?
Im thinking of taking out the tick master cylinder just dont know if the pedal will still be hard. Any input would help. Also if I did change the clutch what is the best one for the money out there. I have 712hp and 646t.
Old Jun 3, 2014 | 08:01 AM
playtoy's Avatar
playtoy
I have the bc3 which has the same cover plate as the bc2 and the peddle is pretty close to stock. I also have the stock hydraulics. I would pull the tick master and see what happens before I changed the clutch.
Old Jun 3, 2014 | 08:20 AM
vrybad's Avatar
vrybad
I also had no issue using stock hydraulics with the RPS BC Triple, very near stock pedal feel.
Many people change to a Tick master cylinder at the suggestion of others, including Tick themselves, and I'm not sure it is necessary in all cases.
I agree with playtoy, swap back to stock to test it, you may find it isn't necessary.
Old Jun 3, 2014 | 09:47 AM
Frans96ss's Avatar
Frans96ss
St. Jude Donor '09
Cant use a tick master with an RPS
Old Jun 3, 2014 | 10:58 AM
Turbo2L's Avatar
Turbo2L
Call RPS and talk with Rob or RJ - they are extremely helpful and surprisingly technical. Typically most higher end products I've dealt with had minimal technical support, but these guys know their product.
Old Jun 3, 2014 | 06:35 PM
07blkvette's Avatar
07blkvette
Thanks for the input. The only problem is that when I had it installed I put the full line from the tick to the slave so now I was told I have to drop the clutch to change to stock hydralics. So I was just trying to decide if I should stay with this clutch so I didnt have to pay labor again.
Old Jun 3, 2014 | 06:57 PM
Icevettez06's Avatar
Icevettez06
I have RPS with twin carbon and tick with no issue. I have used with stock and tick and I seams about the same eater way.
Old Jun 3, 2014 | 07:15 PM
slow ride's Avatar
slow ride
A shop that can build hydraulic hoses might be able to get you and adapter or something. Bring them the fittings and see what happens.
Old Jun 3, 2014 | 07:20 PM
yur2slo's Avatar
yur2slo
You can also get a Tilton 75 series 3/4"(stock bore size) master and change the 7/8" out with that. Summit racing has them and that's what I'm doing.
To Rps bc2 question
