Newbie Needs Some Advice
I've seen a few YouTube videos of high horsepower Corvettes spinning out during acceleration...Z06's and Zr1's. Apparently the spin out/getting sideways can occur when a gear shift occurs at high speed.
I think it's recommended to get rid of the run flat tires and get some softer tires.
Some comments about how to drive this car? I'm wary to drive it in automatic with the pedal to the metal. I think I should drive it in Sport mode and paddle shift it to prevent a surprise upshift.
I'm not 100% naive. I had a 69 Corvette with a clone L88, I had the compression ratio machined down from 12:1 to 11:1. It was about 500 hp flywheel hp. It was a manual tranny. During a full throttle acceleration I could easily control the car, especially by using the clutch. I got some sideways slip on a drag srip, but never worried about loosing it.
So..I've never driven my A & A supercharged car above maybe 3500 rpm and even at that not at full throttle. I think I need to go to a drag strip...although the nearest 1/4 mile strip is in Bakersfield about 200 miles away. Spring Mountain in Nevada is another option.
Question: If I just slam the pedal to the medal in Auto, with stock tires, will the car just accelerate in a straight line?..with no getting sideways issues?
Good luck
The good news is, the independent shafts and traction control on a C6 work very well - so long as you are going in a straight line.
Find somewhere safe and wide open to practice WOT pulls.
#1 rule as far as I am concerned: If you lose confidence in the car's traction, get off the throttle immediately! Most problems I've seen people have is staying on the throttle and trying to drive your way out of it by counter-steering. Unless you are racing for pink slips, don't do that.
And never, ever turn off traction control unless doing burnouts at the dragstrip.
And yeah, consider better tires, maybe even drag radials. But they do affect your handling. Everything is a tradeoff...
NT05's are nice if you don't want to go full drag radial. Anything but the stock run flats!
Good street tires will really help. Bridgestone RE-11, Hankook R-S3, Michelin Pilot Super Sport, Toyo R888. Those tires will do pretty good with the exception of launching hard from a dead stop. For max traction from a stop you are going to want to run a drag radial. Those suck on corners though.
I think the noise & flashing lights are telling you to turn off TC or buy spare set of rear pads.
