DashLogic Discount
Jul 8, 2014 | 02:16 PM
Quote:
Originally Posted by
PalmerPerformance
Can change the PID to just be the analog voltage (10001) and see what voltage we are seeing from the PLX? Also copy and paste your calculation formula so I can check that.
I figured it out
Jul 12, 2014 | 04:49 PM
Dashlogic and Supercharger. What do you monitor?
For an analog fuel pressure sensor, what formula do we have to enter in the Dashlogic configurator?
I have the aeroforce 150 psi fuel pressure sensor.
Jul 13, 2014 | 06:39 AM
PalmerPerformance
Price is back to $249.95
Just ordered one for my 5th Gen since it has a HUD.
Jul 13, 2014 | 01:49 PM
pikkashoe
To enter the equation for AD2 enter this:
(pid(10002) * 36.25) - 18.1
Jul 14, 2014 | 04:37 PM
Streetk14
That is correct. Thank You
That is for putting the wire in "AD2"
Aug 5, 2014 | 11:05 PM
I'm about to buy the dashlogic unit and I'm wanting to watch my fuel pressure. I have the Autometer #2246 pressure transducer. Does anybody have the equation for it?
Does this look correct for the wire in "AD1"
((pid(10001)*25)-12.5)
Aug 6, 2014 | 03:38 AM
St. Jude Donor '13-'14-'15-'16
Has anyone else noticed that their bi-mode exhaust acts up when using their Dashlogic?
I've had several instances where they don't open at high RPMs, or where they open at start up and stay open.
Aug 6, 2014 | 12:13 PM
erick_e
We control the Bi-Mode with the mirror switch. Moving the mirror switch to the left is always closed, middle is factory control, right is always open.
Aug 6, 2014 | 12:18 PM
PalmerPerformance
Brilliant. I thought I was going crazy...
BTW... Great product.
Aug 6, 2014 | 12:21 PM
KENS80V
Do you have a link to where you found the formula for it?
Aug 6, 2014 | 01:23 PM
Aug 7, 2014 | 12:28 PM
KENS80V
Your formula looks correct
Aug 7, 2014 | 12:34 PM
PalmerPerformance
Do I have the brackets in the formula correct?
Aug 8, 2014 | 06:30 PM
KENS80V
It should work as it is, but the first and last bracket are not needed.
Aug 17, 2014 | 11:30 PM
