lets talk rear differentials
Jul 12, 2014 | 09:49 PM
how fast have you been on a built stock case diff ( rpm stg 3-4 ) and how much hp were u making.? when did it break and what broke.?
same for the C6Z diff...
Jul 13, 2014 | 01:04 AM
St. Jude Donor '09
Quote:
Originally Posted by
ironhorse583
I have been 8.5 in a few cars... Never had one break. All RPM built
Jul 13, 2014 | 01:10 AM
the Z diff or the or the base.?
Jul 13, 2014 | 09:27 AM
Redline motorsports tt z06 was running low 8s on a stock z diff without fail until they went glide n 9 inch
Jul 19, 2014 | 01:36 PM
croatbob
That's good information were they using slicks or DR ?
Jul 19, 2014 | 01:42 PM
probably Hoosiers or M/T's
Jul 19, 2014 | 06:39 PM
If I could get 1.6 60 ft I'd be really happy,I'm not sure with a 6spd and 1000hp and nitto dr that's possible .thats a incredibly smooth run.
Jul 19, 2014 | 09:27 PM
St. Jude Donor '09
The black bitch.
This is stock trans and diff
Jul 19, 2014 | 09:30 PM
The black bitch.
Slicks
Jul 19, 2014 | 09:53 PM
Incredible 60fts .i need some slicks
Jul 20, 2014 | 01:28 PM
St. Jude Donor '09
The black bitch.
They are 275 hoosier drag radials... No need for slicks.
Jul 21, 2014 | 12:08 AM
croatbob
wow, that is strong diff for oem.
Can the Z06 diff fit a 4L60 (2005 Z51) with an adapter kit?
Jul 21, 2014 | 10:08 AM
XCELER8
howard went from 6060 to 4L80 to glide. onyl when they went glide did they change to 9 inch rear end
Jul 21, 2014 | 12:26 PM
Can it? Yes. RPM can build a 4l60 that will fit. Needs a different shaft though.
Jul 21, 2014 | 12:42 PM
Just looking at options. I have an 05 rear and since I am only pushing 563rwhp and 20 inch tires and never go to the track I am considering options as RPM might be over kill for me. The adapter plate alone isn't cheap.
Jul 21, 2014 | 02:24 PM
More than an adapter plate, you need the 30 spline shaft too which is $1300-1400.
