C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Piston Question
Old Oct 1, 2014 | 04:25 PM
DSKREET's Avatar
DSKREET
Default Piston Question
Well long story short, I'm in the market for some new pistons. this set up is
LS7
V2 Si @ 8 psi
WCCH heads
LT's
blower cam
Bosch 1000's
E85
Street car
I'm not looking to make huge power, I want 750-800whp. Josh @ A&A said they use dished pistons @ 9.7:1. The problem I have with this is that this will require me to run a different blower to reach my goal. I kinda like running 11:1 so my question.....
- Can I run a forged flat top @ 11:1 with 8-10 PSI on E85 and still be "ok" or should I run a piston @ 10.5:1??
In know about the upgrade bug, but at this point I would be running the car @ around 10 psi for awhile. Thoughts please?
Thank you for reading
Old Oct 1, 2014 | 04:39 PM
Unreal's Avatar
Unreal
Going to need a bigger blower either way.
Old Oct 1, 2014 | 05:03 PM
DSKREET's Avatar
DSKREET
even with 11:1??
Old Oct 1, 2014 | 05:26 PM
Unreal's Avatar
Unreal
Yes. If you hit 750rwhp, it will be a miracle, pushing the blower at or past its limits, and probably a ton of hot air. 700-720 is about all you can get out of a Si-trim, no matter compression/etc. You could always add a 100 shot.
Old Oct 1, 2014 | 05:35 PM
Slo-Poc's Avatar
Slo-Poc
Yes the si will definitely be out of air before your goal. Upgrade to the new Ti or swap to the procharger braket and pick up a D1sc. I have a built stock cube 376 with diamond pistons coated top and sides with my compression somewhere in the 10.2-10.4 range. Gl
Old Oct 1, 2014 | 07:22 PM
DSKREET's Avatar
DSKREET
You know what a Ti will do with a 3.6 pulley??
looks like a blower upgrade is inevitable
Old Oct 2, 2014 | 08:47 AM
Presence Dist.'s Avatar
0Presence Dist.
Former Vendor
call me
Old Oct 2, 2014 | 01:29 PM
Shane@CountyCorvette's Avatar
0Shane@CountyCorvette
Former Vendor
With 750-800rwhp on E85, I suggest looking into a fuel pump upgrade if you haven't already. If switching to the Walbro 450lph, you may still need a boost-a-pump too. Keep an eye on fuel pressure! The last thing you want is to go lean at that power level.
Good luck with your build!
-Shane
Old Oct 3, 2014 | 11:27 AM
DSKREET's Avatar
DSKREET
-Shane
Thank you all for the incite too.
I should of mentioned I am running a A&A dual holley dominator pumps. I think I see a YSi in my future, just gonna have to sell a kidney
To Piston Question
