C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
E force cam choice
Old Dec 27, 2014 | 05:22 PM
KLRVET's Avatar
KLRVET
Cruising
Default E force cam choice to make 700+rwhp
Hey new here . Have a 2009 ls3 vette with e force on 3.00 pulley making 10psi. On e85 lg 1 7/8 headers . Makes 605rwhp. Trying to see what cam or lobes you guys are using to make over 700rwhp. With of course changing to 2.75 pulley. Thanks.
Old Dec 27, 2014 | 10:11 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
You don't mention auto or manual, but either way you should get a cam spec'd for your combination.
I could tell you the specs of the cam I used to make 780hp with an eforce, but it wont help you because I was running an 402, with 245 heads, and automatic. You might need something completely different.
If you are planning to run the 2.75 pulley, you will have belt slip unless you do it right. You might be interested in a few parts I am selling.
https://www.corvetteforum.com/forums...er-pulley.html
Old Dec 27, 2014 | 10:16 PM
KLRVET's Avatar
KLRVET
Cruising
I have fully built 6l80 by century . Stock block. But have rods and pistons. Going in soon. Stock stroke.
Old Dec 27, 2014 | 10:17 PM
KLRVET's Avatar
KLRVET
Cruising
Got some cams specd. Just looking for results and want to see what others have to achieve 700+
Old Dec 27, 2014 | 10:22 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
Don't need an aggressive cam to make power with these blowers, unless you are in to the very heavy lope.
Made 780 with... 226/246 .610/.637 119+3.... and very gentle old school lobes.
Old Dec 27, 2014 | 10:32 PM
KLRVET's Avatar
KLRVET
Cruising
What lobes are you running if you mind me asking
KLRVET's Avatar
KLRVET
Cruising
What lobes are you running?
Old Dec 27, 2014 | 11:05 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
XE lobes.
Old Dec 27, 2014 | 11:11 PM
KLRVET's Avatar
KLRVET
Cruising
Got these cams specd
231/248 120+5
226/246 120+5
229/248 120+6
Old Dec 27, 2014 | 11:12 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
231/248 120+5
226/246 120+5
229/248 120+6
Not too far from mine.
Old Dec 27, 2014 | 11:15 PM
KLRVET's Avatar
KLRVET
Cruising
Yea pretty close . Thanks for the info
To E force cam choice
