C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Solid Roller Discussion
Old May 12, 2015 | 11:56 AM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
Default Solid Roller Discussion
I'm debating going solid roller on my new LSX. To my knowledge the only real "drawback" is having to adjust them and potentially louder valvetrain. But I can't see what would cause the tolerances to change. I've been researching link bar lifters and there is so much contention about preload, small travel vs: regular, etc. There doesn't seem to be a good reliable set out there without breaking the bank. I kinda want to get rid of all that and the wondering about if I'm getting full valve lift and just do away with the hydraulic lifters all together. I already have Jesels (adjustable) so it seems like kind of a no brainer. Anyone have average HP differences for solid VS: hydraulic?
Old May 12, 2015 | 12:03 PM
White_Lightning's Avatar
White_Lightning
damn.. all you houston guys are going race car Solid roller and im here with my off the shelf hydrolic cam thats 6 years old
Old May 12, 2015 | 12:30 PM
Pitufina's Avatar
Pitufina
You need to talk to Kipp from Cammotion. He has the low lash solid rollers that according to him don't require the constant adjustment. He stated that he runs one on his daily driver C6.
Old May 12, 2015 | 12:57 PM
Blackonblacksls's Avatar
Blackonblacksls
I have a Solid roller in one of
My z06s.
It's huge. And I had to spend an extra 30mins adjusting the valves After I installed the motor and drove it a bit.
For a cam its size, it drives really well. Better than a big hydraulic.
It idles perfectly and is snappier and more responsive than anything else I have ever driven.
Also on top of all that it's ****ing quiet.
None of that chatter or sewing machine **** that a lot of ls motors have.
What part of town are you on?
I'll let you check out my car and you'll be surprised how tame the solid stuff is on a street car..
Old May 14, 2015 | 01:00 AM
blackz97's Avatar
blackz97
This.
Old May 14, 2015 | 03:17 AM
inspector12's Avatar
inspector12
Yeah limited travel is what I'd run on a car you drive as much as you do Bill, and what I was going to do when I had to buy those lifters the first time etc... It just so happened they were not limited travel like I was told etc... Same results basically but has at least some hydraulic action to limit how often you would have to adjust them. But I will say MOST solid roller cams will require quite a bit more spring pressure than you've been running so factor in new valve springs in your budget if you should decide to go that route. A mild set of solid roller springs are like 200lbs of seat pressure and 500 open for example. I'd take blackonblacksls up on his offer to check it out also just to see what he's talking about in person if he's here in Houston.
Old May 14, 2015 | 08:39 AM
slow ride's Avatar
slow ride
A nice solid roller setup as above and a intake manifold designed to see gains above 7k will do wonders for extending the powerband to the right.
Old May 14, 2015 | 10:46 AM
Blackonblacksls
Supposedly any of the more mild solid rollers do not require much adjustment.
The best benefit of the cam motion stuff is that you can use your standard ls valve springs.
Like the lunati or btr or whatever else everyone can easily get a hold of and drop right in.
Good lifters are the same cost either way.
Rockers are the same
Cam is the same cost.
If you have aftermarket heads it is easy to go to a larger diameter that can handle whatever sized cam you want to throw at it.
Old May 14, 2015 | 01:50 PM
Turbo-Geist's Avatar
Turbo-Geist
2017 C5 of Year Finalist
What are the benefits of going with a solid lift camshaft? I understand that you can extend the rev limit of the engine and horsepower peak, but doesn't this only apply if you have an intake manifold that can supply the needed airflow for higher rpm power?
It seems like most forced induction LS corvettes with factory intakes are done at around 6500 rpm from a peak horsepower standpoint. What are the major limiting factors?
Old May 14, 2015 | 01:56 PM
Blackonblacksls
All the things I listed above but also copied and pasted below.
Old May 14, 2015 | 02:05 PM
Blackonblacksls
They also make more power, and carry power better with the same parts.
Old May 14, 2015 | 02:14 PM
Blackonblacksls
From what I'm told. When you remove the inconsistency of a hydraulic lifter. That lack of inconsistency leads to benefits at all rpm ranges and throttle positions..
Few people even mentioned better gas mileage in cruising type races and situations
Old May 14, 2015 | 02:44 PM
slow ride's Avatar
slow ride
It's just going to be better control overall. If some of these newer low lash options are solid and can work with lower spring pressures I can't see much drawback for an enthusiast to run them. Now a matching manifold to bring some peak power back without cutting the hood would be nice if it were not $2k+
Old May 16, 2015 | 10:53 AM
5 Liter Eater
St. Jude Donor '11
Well I'm over it. Sticking with hydraulic.
Old May 16, 2015 | 03:10 PM
ajrothm's Avatar
ajrothm
Good choice.. Save yourself a lot of headaches that you don't need for your combo.
Old May 16, 2015 | 03:30 PM
Blackonblacksls
If you have a blower or turbo car.
The adjustment of rockers would be pretty insignificant compared to many of the headaches you are used to..
Old May 16, 2015 | 05:32 PM
ajrothm's Avatar
ajrothm
I own 2 solid roller BBCs... I'm fully versed in solid roller stuff.... For something you drive a lot and idles a lot...lets just say a hyd roller is usually easier to live with.... Especially on a combo that is 7200 rpm or less in a LS platform.
You start eating lifters and pumping metal through the motor, you'll think about running a solid on a weekly driven car that gets a bunch of miles.
The adjustment of the rockers isn't ****.... Its the lifter maintenance that is the pain in the ***.... Especially having to pull heads on an LS to get the lifters out.
To Solid Roller Discussion
Old May 16, 2015 | 05:49 PM
Blackonblacksls
Seems the majority of boosted ls motors are getting pulled fairly often anyways?
What's a new set of lifters to go along with the bearings and cranks and rods and Pistons you are buying anyways??
Old May 16, 2015 | 05:57 PM
ajrothm's Avatar
ajrothm
Seems the majority of boosted ls motors are getting pulled fairly often anyways? This is true! LOL
This is true also...however I don't want to pull a motor because of a lifter failure... I'd much rather pull a motor because I over powered a crank and flexed it...LOL (not really)... I hate pulling motors as well as heavy maintenance... Hence why I suggest a hyd roller...
I just don't see the benefit of a solid roller in a LS platform with its light valve train and straight push rod angles, IF you're gonna keep the RPMs to 7200-7300 or less.... Especially in a forced induction setup that makes plenty of power. Why add even MORE maintenance...?.
In an all motor, high rpm deal, solid roller is the way to go....Not that you'll be driving one that much on the street.
Old May 16, 2015 | 06:03 PM
Blackonblacksls
It's funny that you say that. As I'm entering the freeway with high rpm solid roller car.
