Gates Belts - k060891 or k060895 - no Heavy Duty Green???
#141
Then it sounds like they don't make it currently. If there was one 1/2" up or down, you maybe able to use that depending on your tension situation, but they are 1"+ off so looks like you are stuck with a normal belt for now, not that is a bad thing.
#142
I have the updated A&A procharger bracket. Just trying to order the right ones since TX2K is so close.
#143
Would be same size as you have now. K100935RPM. Right now it looks like nothing even close to that.
I've noticed zero difference with mine so far. So if there is an advantage, it will be life. So until I get to 15-20k miles on this belt, can't really say anything good/bad besides it works just like any other belt.
@Unreal; The RPM belt is going to take the abuse better than any belt out there. Where a polyester corded belt stretches, the aramid RPM won't. A polyeter cord can only stretch so many times before it lets go. Every time it stretches there is a little bit of slip and heat generated. As we all know heat and slip kill belts. On street driven cars that see redline occasionally, this might not be an issue of immediate concern. On track oriented car, with sustained heavy loads, this will be noticed immediately.
The aramid cord coupled with the dual adhesion gum layers creates a belt that wont have the dreaded belt slap at certain frequencies. This will manifest itself as broken tensioners, belts even idler pullies.
GM has superseded ALL of their LT4 and LSA supercharger belts to aramid cord from the factory. They didn't do that to save costs, I can tell you that. What they don't have is the stickier rubber, dual adhesion gum layers or sizing for aftermarket blowers and pulley setups that the RPM line offers.
This is all from my conversations with Gates
#145
These 2 are the closest
K080507RPM K08 1 3/32” x 51 1/4” - Black 8 50.748 Outside Circumference 51.25
K080525RPM K08 1 3/32” x 53 1/8” - Black 8 52.6 Outside Circumference 53.169
#146
Received 1,194 Likes
St. Jude Donor '15
Rock auto seems to have the best selection of these belts at somewhat reasonable prices for anyone that is looking
#147
dave at superchargers online
Chad and Drew are the reps for the RPM line and are based here in Colorado, I've used these belts on a couple different cars with good success
#148
St. Jude Donor '15
Are they keeping these belts in stock?
#150
You can't beat $45.00 @ Rockauto. They usually say it takes 5 days to get them, but they typically ship them out in 2-3 working days. I've ordered 3 RPM belts from them so far.
Here ya go:
https://www.rockauto.com/en/parts/ga...7RPM,belt,8900
Here ya go:
Chiselchst (06-23-2017)
#151
#152
CI GS (06-24-2017)
#153
If you guys have sizes you want set up just fill this out
http://www.gatesracing.com/contact
